04 V-10 Cat problems
Old Jul 30, 2008 | 06:48 PM
Chopper_WSP's Avatar
Chopper_WSP
Hi all, I have a question, I have a 04 Super Duty w/6.8, I have damaged the cat while off roading(it is crushed and I think the cake inside broke loose), the guy at the local muffler shop says he will cut it off and put a "test" pipe for $40, but he claims to check engine light will stay on...there is no O2 sensor past the cat so I dont see how this is posible...any of you run into this before? Thanks all,Chopper
Old Jul 31, 2008 | 03:45 PM
Bear River's Avatar
Bear River
Former ******
Ok, you weren't clear on 2WD or 4WD, but I am showing several options. One converter has a 3 bolt front flange, and an O2 sensor behind it. Another option has a 4 bolt front flange and an O2 sensor on the top of the cat in the middle of the body. The third option is that there is a y-pipe that may be used in conjunction with one of the above mentioned rear converter units. In any case, all options my catalog is showing indicate that the rear cat is monitored.
The unit we would recommend to replace it cost effectively is this
Item Details
Old Jul 31, 2008 | 03:54 PM
dkf's Avatar
dkf
If theres no O2 sensor after the cat your good to go. I have a Dynatech bullet shaped cat on my 04' 6.8l no codes, no problems. I don't have an O2 sensor after the cat, just one O2 sensor per bank right after the exhaust manifolds. The vast majority of V10 don't have EGR or a rear O2. CA SDs or SDs sold in states with similar emmision requirements as CA will have EGR and a rear O2 to pass emmisions. Throw on a universal cat and keep on truckin.
Heres a thread of the exhaust I put on my V10. https://www.ford-trucks.com/forums/7...-fm70-mod.html There is pics there of the cat. My dad has an 03' V10 but a CC he is running a Universal cat and has no rear O2 also
Theres a lot of good info on the V10 up in the V10 forum, stop by sometime.
Old Jul 31, 2008 | 06:51 PM
Bear River's Avatar
Bear River
Former ******
Starting in '03 or '04 many super duty vehicles had to start meeting OBD-II requirements. Your truck I guess could go either way, and my catalog gets sketchy on anything newer than '03. If you have the 4 bolt flange design, your rear O2 sensor is in the top of the cat. If you have the 3 bolt design and you don't see a sensor, then the cat isn't monitored, but you will probably need one to pass visual inspections. If you are in a smog area, you will have to pass smog tests too. One way or another you need a cat.
Old Jul 31, 2008 | 08:48 PM
Chopper_WSP
Thanks all, chopper.
Old Aug 1, 2008 | 07:06 PM
dkf's Avatar
dkf
8800 CVWR has completely different emmission requirements. My 04' is OBD-2 but it functions like and OBD-1 because of the weight classification.
I have to have a cat on my truck to pass the visual inspection in my state, but I'm shure the laws vary state to state.. I have a 3-bolt flange.
