Sponsored by: Auxito
Intermittent Rattle Underneath
Old Jul 6, 2008 | 07:57 PM
dlinkbham's Avatar
dlinkbham
Sounds like a bracket loose. Set cruise at 77 and when the cruise lets off the gas, you can hear the rattle. It does it at other various times. Ford dealer says they can hear it but they can't tell what it is. They do not think it is the rear end.
I see a lot of posts that says check the heat shields, check for rocks in the heat shields, or get it on a rack and bang on different parts of muffler with a rubber hammer to create the noise with a tech underneath.
I travel the interstates a lot so after a couple of hours it is really annoying.
Thoughts???
Thanks
2001 F150 Supercrew 2wd
Old Jul 6, 2008 | 08:04 PM
slc10844's Avatar
slc10844
The first thing I would check are the catalyic converters. When they start to break up they will rattle.
Old Jul 6, 2008 | 08:14 PM
AzBlueWolf's Avatar
AzBlueWolf
Had a couple trucks that needed to add weights to the exhaust before rattle would go away...
check TSB's
Mark
Old Dec 28, 2008 | 10:27 PM
B's FX4's Avatar
B's FX4
so what do you do when the cat is rattleing? can you strip that outter part off or is that part of the cat? mine does it once and awhile and it is driving me crazy!
Old Dec 28, 2008 | 10:53 PM
caseydudem's Avatar
caseydudem
No I think he ment it is coming apart inside the cat, and if that is the case you can only replace it. If it is the outside shield that is rattling then you should be able to move it with your hand to see if there is play. Of course only do this when the motor is cool.
Old Dec 29, 2008 | 09:57 AM
B's FX4's Avatar
B's FX4
ok, this morning i went out there and looked at it again, the cat is falling apart and rattling, so i took a pair of channel locks and bent the edges back together as tight as i could and it stopped the rattle ! was a pretty easy fix, hope it helps out and thanks for your guys inmput
Old Mar 13, 2009 | 02:05 AM
B's FX4's Avatar
B's FX4
yeah, well rattle is back, looks like the cats are falling apart big time....guess its time to replace em
Old Mar 13, 2009 | 05:30 PM
AzBlueWolf's Avatar
AzBlueWolf
How many miles on the truck...some emissions components are covered to 70 or 80k miles
Old Mar 14, 2009 | 01:18 PM
B's FX4's Avatar
B's FX4
i will have to check that out, i have 66k on it now, going to investagate this afternoon in the garage what else i can do
78sForever
Modular V10 (6.8l)
Feb 2, 2015 03:41 PM
damone
2004 - 2008 F150
28
Apr 30, 2012 10:17 AM
ssimpson6
Oct 3, 2006 09:35 PM
knockturnalstorm
Nov 30, 2003 08:29 PM
spoon059
Dec 12, 2002 07:21 AM
