Sudden Boost Drop
Old Jul 6, 2008 | 09:49 AM
megawatt00's Avatar
megawatt00
It really seems like defueling. When this happens, does your tach drop also?
Old Jul 6, 2008 | 04:45 PM
1996pwrstrk's Avatar
1996pwrstrk
When my truck defueled because of over boost I still had power not as much but I had some and some boost to it never went all the way to 0. Pull the red line off your waste gate and put on the stud of the IC clamp and give it a run and see if if it does it again.
Old Jul 6, 2008 | 07:08 PM
birdog65's Avatar
birdog65
What is the IC Clamp?
Old Jul 6, 2008 | 07:11 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
The intercooler clamps. They are the clamps that hold the blue silicon hoses on the metal tubes. The pressurized air from the turbo flows thru them, thru the cooler, then back to the intake. If you are losing pressure you are losing boost. Same thing.........
Old Jul 6, 2008 | 07:13 PM
ron's power stroke's Avatar
ron's power stroke
the inter cooler tube running from the turbo to the inercooler have 2 rubber boots on both tubes...them boots are held on with what looks like hose clamps.. IC= intercooler
Old Jul 6, 2008 | 07:14 PM
ron's power stroke
I'm too slow..ruff weekend..
Old Jul 6, 2008 | 07:17 PM
joegebff's Avatar
joegebff
Im at work, haven't been fishin......
Old Jul 6, 2008 | 08:36 PM
birdog65's Avatar
birdog65
By taking the wire off of the waste gate, does that fool the system so that it doesn't defuel and/or open the waste gate? Can this wire be left off all the time?
Old Jul 6, 2008 | 08:43 PM
1996pwrstrk
Its not a wire its a hose and with it off it the waste gate will be disconnected and will stay closed and not bleed off any boost.
Old Jul 6, 2008 | 09:19 PM
birdog65's Avatar
birdog65
Thanks Dave, will the truck still defuel with the hose off?
Old Jul 6, 2008 | 09:56 PM
HKusp's Avatar
HKusp
If it is a defueling issue and not a waste gate opening and bleeding off your boost, then yes, the truck will still defuel. They are trying to make sure your wastegate isn't opening and sticking.
Old Jul 7, 2008 | 08:40 PM
birdog65's Avatar
birdog65
Ok. I took off the tube to the wast gate and put it on an IC clamp. I then went for a drive and put my foot into it. The pressure drop is at 15 psi, but my rpms stay up. I'm going to go change the oil and see what happens.
Old Jul 8, 2008 | 12:28 AM
  #28
birdog65's Avatar
birdog65
I want to thank everybody for their help. I changed my oil and the problem has gone away. I went full throttle up a big hill and held at 25 psi without a problem. I guess the high pressure fuel system doesn't like old oil. I can only assume that because I had about 13,000 miles on the oil that the anti foam properties had depleted which led to the fuel/turbo problems.
Now this brings on a whole another topic as far as extended oil changes on Fords because of their oil fired injectors. In case anybody cares, I was using Amsoil Synthetic 15W-40W with their oil bypass filter system. I just replaced the filters and refilled with Delo 400LE 15w-40w. I have 96,000 miles on the truck and the synthetic was leaking out and I was using oil at about 1 quart a month or about every 1,600 miles. I'm hoping the leaking oil and consumption will reduce with the dino oil. Take care everyone.
Old Jul 8, 2008 | 07:06 AM
  #29
zx250's Avatar
zx250
Of the next Riffraff East
Hehehe, see post 2 of this thread. Anyway, glad you got it fixed and about as cheap as it could get.
c2z4s9
73
Feb 29, 2016 07:14 AM
h-m
1983 - 2012 Ranger & B-Series
Apr 9, 2015 04:01 PM
Fatfenderford
Apr 1, 2015 12:07 PM
1966twinI
Oct 8, 2014 11:24 AM
Piolet
May 26, 2014 05:51 PM
