Engine block runs hot
Old Mar 31, 2015 | 04:07 PM
Fatfenderford's Avatar
Fatfenderford
3rd Gear
Here's the information all of you ask for:
Raytasch: it runs hot if I let it idle ( without driving it) and when it's under power. I'm using an auto meter (non-digital) gauge and a new Gibson aluminum radiator that is sized for the 351.
91 F-Body: operating range of oil pressure is 55-60psi at start up and drops to about 10 psi as engine heats up. Oil pressure if I let it idle (not driving) follows the same pattern. Idle when hot after driving is about 10 psi. When engine is under power (normal driving) this will happen in about 10 minutes time.
52 Merc: there is a new high torque starter, new coil, and a new battery. I just had the timing checked recently.
Old Apr 1, 2015 | 12:07 PM
petemcl's Avatar
petemcl
Suggest that you post this to the original thread. By itself it is most confusing.
benbuilder
30
Nov 30, 2022 06:38 PM
jackietreehorn
Mar 17, 2018 09:12 PM
Fatfenderford
Apr 1, 2015 09:04 PM
El Padrino
Feb 28, 2013 02:44 PM
tundraathome
1983 - 2012 Ranger & B-Series
Oct 7, 2006 10:12 AM
