Camber/caster?
Old Jul 5, 2008 | 01:02 AM
StealthWyvern's Avatar
StealthWyvern
Camber/caster?
I'm curious do they make camber/caster bushings or whatever they are called for the 2wd application? I dont want to purchase new springs for the front as I like how it sits. According to the shop the only way that I can correct my alignment issues if to purchase new springs. So is their another way???
Old Jul 5, 2008 | 06:41 AM
alz's Avatar
alz
Here you go.
Superlfit Adjustable Alignment Bushings Pair
Old Jul 5, 2008 | 11:44 AM
StealthWyvern
Thanks Alz, I forgot to mention that they said the truck already has thebiggest bushign they have? Does that effect anything?
Old Jul 5, 2008 | 01:44 PM
StealthWyvern
I found my alignment spec sheet and I'm if its to far out of spec for these bolts. If not how many sets should I get?
Front : Left.............Front: Right................Front
0.8 Camber.........-2.5 Camber.............3.4 Cross Camber
-0.87 Toe..............1.25 Toe.................. 0.038 Total Toe
Rear : Left...............Rear : Right................Rear
-0.5 Camber..........0.0 Camber.............-0.4 Cross Camber
0.22 Toe..............-0.04 Toe..................0.17 Total Toe
.................................................. ...........0.13 Thrust Angle
flcracker9
Dec 13, 2012 10:11 PM
jimmycoc
Aug 25, 2011 08:44 AM
GaryF629
1983 - 2012 Ranger & B-Series
Apr 12, 2010 10:16 AM
hotrodmerc
Bronco II
Mar 6, 2005 09:28 AM
