A/C Schrader Valve Tool
Old Jul 4, 2008 | 09:07 PM
SpringerPop's Avatar
SpringerPop
Yes, I've looked at the HVAC forum with the search engine, found some information, but nothing definitive.
I need to replace an R-134a Schrader valve, or maybe just tighten it a bit.
Can a valve stem tool for a tire stem be used? For both sides? Only one side? Neither?
Along the same line of questioning, where do I buy replacement valves in quantities of one?
If a special valve tool is needed, where do I add that to my bag-o-tricks?
I'm asking here, rather than over at the HVAC forum, because I'm more likely to get an answer instead of an opinion.
Thanks,
Pop
Old Jul 4, 2008 | 09:15 PM
willeo6709's Avatar
willeo6709
I am reaching wayyyy into the memory here but I think the tire valve stem tools work. Its worth a shot....I recall them working for R12 valves. If its leaking I'd probably get the right valve, referigerant is not cheap nowadays, and it has the compressor oil in the mix too.
Old Jul 4, 2008 | 10:00 PM
mech2161's Avatar
mech2161
It will work for one side, not sure about both. I'd have to look at my truck for sure.
Old Jul 4, 2008 | 10:45 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Pop, make sure it's a Schraeder type valve. My 98 chevy truck had what I 'thought' was a Schrader but it actually had a ball in there that did the sealing. The replacement was about 10 bucks for the good brass one.
The Schrader tool and the valve stems can be had at O'Reily's. It is twice or so larger than the tire tool IIRC. Don't have it with me to compare.
I agree to do it right or you'll end up chasing your tail.......sorry, couldn't resist.
Old Jul 5, 2008 | 12:11 AM
1996pwrstrk's Avatar
1996pwrstrk
Marv go to Autozone and see what they have they show this for our trucks.https://www.autozone.com/R,NONAPP138...ductDetail.htm
Old Jul 5, 2008 | 01:14 AM
SpringerPop
Perfect, Dave! Thanks!
I'll drop by there tomorrow.
Pop
Old Jul 5, 2008 | 09:22 AM
joegebff's Avatar
joegebff
If you lose or have lost much Freon, you might should go ahead and pull a vaccum and then re-charge. It would be worth the $$.
Old Jul 5, 2008 | 09:26 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I'm probably not going to be much help here but I bought the fancy tire valve tool and it worked perfect on both the high side and the low side. Now here comes the not much help part. I can't remember if it was for one of my R-12 systems or 134 systems.....LOL
jetfiremuck
Aerostar
Apr 13, 2017 08:26 AM
scrambledlife
Jul 14, 2016 06:52 PM
cajuntrentf100
May 9, 2016 01:05 PM
Tugly
Mar 10, 2016 09:56 PM
JimRietz
Jan 11, 2011 01:37 AM
