4X4 Question
Old Jun 30, 2008 | 09:54 PM
schlepprock250's Avatar
schlepprock250
4X4 Question
Hey guys, Ok...when I put my truck(in sig.)into 4 wheel high(I dont know about 4 low) it still spins the rear wheels and it dont seem to engage.Now I havent checked it cause I havent had time but I thought maybe I would throw it at you guys and see what yall think. And I also havent got out and locked the hubs in either,(still have stock auto lockers).Thx......
Schlepprock
Old Jun 30, 2008 | 10:00 PM
superduty4x4's Avatar
superduty4x4
Turn on your A/C, if the ESOF is failing it will default to the defrost vents.
Old Jun 30, 2008 | 10:10 PM
schlepprock250
Well...I run the A/C all the time and it blows through the dash like its supposed to, so I know its not a vacumn leak so to speak.
Old Jun 30, 2008 | 10:21 PM
hucka1a's Avatar
hucka1a
https://www.ford-trucks.com/forums/5...ped-workn.html
I hope this helps.
Old Jul 4, 2008 | 09:04 PM
schlepprock250
Ok....I wanted to take a minute to share my findings about my 4X4 question.The 4X4 wouldnt engage so I checked and sure enough(like I was advised on here)the vacumn(lol... ?spelling)hoses were both rotten,I replaced both hoses and all is well now.Thx....
Schlepprock
Old Jul 5, 2008 | 02:16 PM
cps's Avatar
cps
Just some advice when you have rotten vacuum hoses. Depending on where they are cracked, and for how long, there is a possibility of water has gotten in to your hubs thru that crack and you will get corrosion inside.Not good and could cause problems down the road. Just something to think about. Roy
