please hheellpp!!!!
Old Jul 4, 2008 | 06:54 PM
jugganot's Avatar
jugganot
please hheellpp!!!!
hay all,
ok, let me give you guys the low down. see if you can help me out.
i was driving home from work (about 30 miles) and everything sounded fine. i pulled up to the stop light and as my trucks idle started coming down, i noticed it started getting rough. i reved it up to 1000 rpm to feel it and hear it, and blue/grey smoke started pouring out the exhaust, and the idle got worse. i tried reving it up a little and it would choke out. it didnt want to rev at all. kinda curious as to why my truck would be doing this, and any input would be greatly appreciated.
for my info: 2002 f-250 7.3l zf6 tranny 4" exhaust k$n intake edge tuner w/attitude.
thanks for your time.
Old Jul 4, 2008 | 06:59 PM
Lovin7.3's Avatar
Lovin7.3
Welcome to FTE!!
cps maybe? Did it just do it once and then act fine? I would guess the CPS.
BTW trash the K&N and get a 6673 filter and also get rid of the edge for a DP tuner. You will come to realize this.
Once again WELCOME!!
Old Jul 4, 2008 | 07:04 PM
Greywolf's Avatar
Greywolf
Sounds kind of ominous... Blue smoke is usually oil.
Excess fuel would make black smoke.
I do remember one or two experiences with people at RV dealerships that filled up the diesel service trucks with regular gas - and that had similar results. If I remember right, 7.3's have a water seperator dead center on top of the engine that can be drained to purge it, and fresh diesel can be added directly to it as a way to find out if it's something in the fuel.
Old Jul 4, 2008 | 07:06 PM
F350-6's Avatar
F350-6
Welcome to FTE. I assume you got a check engine light when this happened? Do you know anyone who can pull the codes for you?
Did the truck just run rough like it wasn't hitting on all cylinders, or did it act more like it was trying to die?
Just to rule out a couple of basics, do you have over 1/4 tank of fuel, and is the oil level low?
jugganot's Avatar
jugganot
no, it sarted yesterday. so i figured i would let it cool down and try it again later. well, this morning i went out and checked my oil, i just changed a couple of weeks ago, and everything was fine. started it up in stock tune and it idled rougher than a cobble stone driveway and would lay a smoke screen in the road.
Old Jul 4, 2008 | 07:11 PM
jugganot's Avatar
jugganot
already tried draining the diesel and everything was fine. i realize blue smoke is oil, thats why i was concerned and posted my problem.
Old Jul 4, 2008 | 07:15 PM
Greywolf's Avatar
Greywolf
I'd say it's time to get a diesel engine compression guage and find out if the cylinders have any problems.
Old Jul 4, 2008 | 07:16 PM
jugganot's Avatar
jugganot
i had a litle over half a tank and the oil was a little low so i added to it and it didnt fix anything. the p.o.s. edge tuner always throws the check engine light, so i woulndnt be able to tell if the probplem threw a code. i dont have access to a scanner. i did start the truck after it was cool, and the same problem arose and no light trown.
Old Jul 4, 2008 | 07:20 PM
F350-6's Avatar
F350-6
Lots of smoke is not a good sign. A loose UVCH clip might smoke a little, but not enough for a smoke screen. Try pulling the oil cap with the engine running and check for blow by. Do you see light to moderate smoke out the fill neck or does it puff like a steam engine?
Is there any signs of oil in the bottom of the fuel filter bowl or in the engine coolant?
Old Jul 4, 2008 | 07:31 PM
jugganot's Avatar
jugganot
ok so i checked the coolant, no oil, i checked the oil filler cap, no smoke at all, and i checked the fuel bowl and no oil. im not sure what the uvch clip is...
Old Jul 4, 2008 | 07:39 PM
F350-6's Avatar
F350-6
We usually don't see much smoke associated with this type of thing, but the UVCH (Under Valve Cover Harness) is the wiring harness under the valve cover that provide power to your injectors and glow plugs. If you look on the inboard side of each valve cover, you will see a flat wiring connector that plugs right where the VC gasket is. There is just a pass thru connector in the gasket, and a similar plug inside the valve cover. Those have been know to come loose and will make your truck run without a few cylinders. Let me look something up. In the mean time, if you have an ohm meter you can test this by unplugging the 9 pin connector at each valve cover.
The 9-pin plug is wired as follows:
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
The injectors fire with a 115VDC signal from the IDM. Do Not pierce the wires to test.
Test between "I" and "C" to test the injectors, should be less than 5.0 Ohms.
To check glow plugs Test between "G" and battery ground. Should be between 0.6 and 2.0 Ohms
Here's a link with pictures so you can see what it is you're looking for with the meter.
https://www.ford-trucks.com/forums/27...or-wiring.html
Old Jul 4, 2008 | 07:41 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
I would certainly ohm out the Under Valve Cover harness. It is fairly simple to check to rule that out. Do a search for it or just wait a bit, someone better than me will link it for you. It will cause rough running ans SOME smoke, not usually tons and it is generally whitish/grey, unburned fuel.
Old Jul 4, 2008 | 07:42 PM
joegebff's Avatar
joegebff
DOH......
Old Jul 4, 2008 | 07:52 PM
jugganot's Avatar
jugganot
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
the link didint work for me. i will check the uvch and get back to you with what happened. thanks again for the help.
Old Jul 4, 2008 | 08:01 PM
F350-6's Avatar
F350-6
I seem to be screwing up links a lot lately. Sorry. Let's try again
https://www.ford-trucks.com/forums/2...or-wiring.html
Also while you're playing around under there, not many people here are fans of the K&N. You might pull the intake hose off the turbo and have a look at the wheel inside there. The wheel should have no noticeable play in and out, and very little up and down play. The blades should be smooth with no signs of pitting or rough edges. You also shouldn't see any signs of dirt in there.
Do you know anyone with a scanner capable of checking a Powerstroke? An injector buzz test and cylinder contribution test would be nice. If we can't come up with anything else you may be forced to pull the valve covers and check out things out visually.
