help!!! hpop!
Old Jul 4, 2008 | 02:10 PM
andrews1996psd's Avatar
andrews1996psd
Exclamation help!!! hpop!
hi i have a 1996 7.3 that has been leaking oil from the high pressure oil pump can anyone give me directions or a web site that can help me replace it thanks
Old Jul 4, 2008 | 02:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Maybe this helps you
http://www.diesel-central.com/News/oil_pump.htm<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
https://www.ford-trucks.com/forums/534153-sd-hpop-install-write-up-part-1-a.html#post4017748<o></o>
<o> </o>
Old Jul 4, 2008 | 10:30 PM
scatgo's Avatar
scatgo
What makes you think it is the HPOP?
Old Jul 4, 2008 | 11:38 PM
andrews1996psd
it was leaking from the turbo i got that fixed its coming from the top of the engine and from the front
Old Jul 5, 2008 | 08:22 AM
scatgo's Avatar
scatgo
How is the truck running? Sure its oil and not fuel? If it is the HPOP might just be a gasket between the HPOP and the reservoir. You might want to start by giving it a good cleaning to see exactly where the leak is coming from. What year is your truck? How many miles?
Old Jul 5, 2008 | 09:26 AM
andrews1996psd
it will start up and die when the engine is could and have a ruff idle until it is worm. I am 99% shore it is oil, it was leaking diesel i replaced the lifter pump and had to put a new fuel canister because it was cracked i have have the gasket for the hpop it is just about the last thing i have not replaced or rebuilt on top of the block
1996 195,600
Old Jul 5, 2008 | 10:39 AM
scatgo's Avatar
scatgo
Did you ever remove the plug on top of the HPOP reservoir to see if it is staying full of oil? Some of these trucks have a problem with the oil draining back down from the reservoir when the engin is not running witch may be causing the problems you are having with the way your truck is running. Not sure if your truck has the drain down problem. The thing is I would hate to see you replace what may be a expensive part and it is not going to fix the problem. There is a injector pressure regulator on the HPOP that may be responsible for the problems you are describing.
Old Jul 6, 2008 | 11:58 PM
andrews1996psd
no i did not but i am going to replace the regulator and all of the gaskets
Old Jul 7, 2008 | 02:58 AM
kawa's Avatar
kawa
Andrews1996PSD:
I would strongly suggest that you listen to the advice that you are being given so you can properly isolate the exact location and the identity of your leak.
You need to throughly clean the "Valley of death" and mop it dry with many paper towels. Then armed with a "Good" flashlight and a clear swivel mirror you will be able to trace the leak and probably save yourself much time and money.
JMHO,
Rog
Old Jul 7, 2008 | 11:44 PM
andrews1996psd
thanks guys, the oil lis coming from the seal around the hpop
regulator looks dry but should i replace it?????
Old Jul 8, 2008 | 05:27 PM
scatgo's Avatar
scatgo
To be perfectly honest with you I am not sure. I am a bit of a newbie myself. Hopefully the gurus will jump in and try to help you figure out why your truck is not running to good.
Did you get a chance to pull the plug of the top or the HPOP reservoir to make sure if it is staying full?
O,yea, by the way. Welcome to the club........
Old Jul 8, 2008 | 07:48 PM
glasseater's Avatar
glasseater
i wish i knew anything about replacing a HPOP just tryin to put you back at the top of the page
Old Jul 8, 2008 | 11:28 PM
andrews1996psd
yes, there is some oil standing in the hpop
Old Jul 9, 2008 | 08:50 AM
plowhand's Avatar
plowhand
Playing in the Dirt
If the gasket on the HPOP reservoir is the only thing that is leaking, I would replace the gasket and while I was in there, I'd repalce the o-rings on the IPR, thats it.
Old Jul 19, 2008 | 09:37 PM
scatgo's Avatar
scatgo
How's the truck running?
