help!!! hpop!
Old Jul 19, 2008 | 10:05 PM
racenitro's Avatar
racenitro
If it is like my current problem, Ihave a BAD O-Ring on the plug near the driver side of the pump...the plug has the long tang on it...O-ring was shot and it leaked a lot of oil but still ran well.
tried to replace the o-ring but apparently there are two different types of plungers under the plug. The old pump I have had a square plunger but this had something else that disappeared when I pulled the plug...
Wouldlove to find an exploded view of the HPOP so I can tell what this peice looked like.
Am having to put old pump back in whil I wait for another eman pump. The pump that developed the leak was a reman that I putin last year. This plug had the threads stripped on it so it was never tight and I did not check it before installing...after 9 months it loosened up and destroyed the o-ring...
Now I have an expensive repair for a 60 cent piece.
LOBO2
1978 - 1996 Big Bronco
Oct 22, 2016 02:53 PM
1996ford
Jun 8, 2015 10:04 PM
LAbronc
Feb 16, 2014 08:40 PM
onriver365
Jan 6, 2013 08:49 PM
colesdad
Jan 23, 2009 01:25 AM
