what does this plug go to???
Old Jul 3, 2008 | 04:06 PM
projectbad78's Avatar
projectbad78
its on my alternator/regulator harness
and this one... i know where it hooks up to but what does it do?
Old Jul 3, 2008 | 04:07 PM
projectbad78
sorry disregard the second pic i meant to put a pic of the 2 wire connector
Old Jul 3, 2008 | 04:59 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Well, in the first pic, that connector plugs into the main harness for trucks with the ammeter gauge.
This altenator harness will not work for trucks with Warning lights.
Old Jul 3, 2008 | 05:26 PM
projectbad78
i dont really care about the warning light, i have aftermarket guages...can i cut it off and still use it?
Old Jul 3, 2008 | 05:34 PM
projectbad78
oh yeah,...thanks...do you know what the 2 wire plug that looks like this is for? i know what it plugs into, just not what it does
Old Jul 3, 2008 | 06:15 PM
81-F-150-Explorer
No, you will need a altenator harness for warning lights.
This harness hooks the voltage regulator to the altenator and to the main harness differently. you would have to hack that harness to bits and change some wiring around to make it work.
Find a Altenator harness for warning lights, or replace the main harness for one with gauges.
I do believe some of the econoline vans use these same altenator harnesses too. But check to make sure.
As for the two prong plug, I need to see a picture of it to be sure.
Old Jul 3, 2008 | 06:46 PM
projectbad78
this is the plug in the upper right
Old Jul 3, 2008 | 07:02 PM
fdude64's Avatar
fdude64
if i am not mistaken it is for the higher amp alternator and runs to the voltage regulator
Old Jul 3, 2008 | 08:34 PM
81-F-150-Explorer
Yellow/Black and Red/Orange wires?
That is the plug that goes directly to the ammeter gauge via the main harness.
Old Jul 4, 2008 | 11:32 AM
projectbad78
no, in the upper right the plug has a green wire from the regulator and the other wire goes to the alternator....this plug is on both style harnesses....im just wandering what it goes to.....it plugs into my main harness
Old Jul 4, 2008 | 11:37 AM
fmc400's Avatar
fmc400
MSEE
As I said before, you should post this in the Electrical forum and Franklin2 should be able to help you.
Old Jul 4, 2008 | 11:52 AM
81-F-150-Explorer
Green/Red Wire.
On Trucks with warning lamps, Green/red wire goes to altenator warning lamp.
On Trucks with gauges, goes to ignition switch.
