Old AC leak
Old Nov 24, 2002 | 10:41 PM
Xwarrior86's Avatar
Xwarrior86
Old AC leak
Ok, Got an '86 f250 lariat that should have AC, but apparently hasn't since about '96. (it was used) anyway, I've tried recharging it 2 or 3 times and each time it will last about a month or less and then it's nothing but hot air. (sucks in the summer)The bearings seem to be on the compressor, but I just don't know where in the world the air is leaking. Changed all the valve plugs and checked the hoses. Both the freon detector and the bubble trick showed nothing. I really would like to get this turd fixed so help me however you can. Thanks
Old Nov 26, 2002 | 06:55 AM
tomw's Avatar
tomw
Old AC leak
Check the front seal on the compressor. When doing leak checking, freon will fall to the floor. So, when checking the evap, keep the car closed for a while, HVAC in the 'off' position. Take the detector down by the recirc door, opened by hand, and see if it goes off. You would have captured the leaking R12 inside the plenum, and detected it as it fell out the recirc door.
Most leaks will carry oil out with the refrigerant. Look for oily spots on the hoses and at connections.
If it leaks out in 2 months, it should be detectable...
HTH
tom
Old Nov 27, 2002 | 01:22 PM
Mil1ion's Avatar
Mil1ion
Old AC leak
Redneckfordf2502002
Jun 24, 2015 07:33 PM
86-IDI
Aug 25, 2014 11:11 AM
whalerron
Jun 4, 2014 11:09 AM
Normspeed
1978 - 1996 Big Bronco
Dec 7, 2009 10:08 AM
Rintin69
Jun 9, 2006 06:14 PM
