tucked
Old Jul 3, 2008 | 01:09 PM
sdetweil's Avatar
sdetweil
Yeh, looks like they just threw the tires & wheels on without taking the size height impact into account.. like its in stilts..
Sam
Old Jul 3, 2008 | 01:18 PM
CharlieLed's Avatar
CharlieLed
Can you say "donk"! If a person doesn't like the big wheel openings on the F100 then close them up a little. There have been many magazine articles done on moving the openings forward and/or modifying the openings to get a desired look. Somehow the large wheel diameters with the rubber band tires on an early F100 just look wrong...then again they don't look so hot on early Caprice's but that hasn't stopped some folks from doing it...to each their own.
Old Jul 3, 2008 | 02:35 PM
56efffie's Avatar
56efffie
Not to be a party pooper, But I can tell just by looking that you would not be able to lay frame with 20/22, the top of the wheel will definately hit the top of the fender before the frame hits the ground. After tucking I think the running boards would still be a couple inches off the ground.
Old Jul 3, 2008 | 04:47 PM
Layed Out 100's Avatar
Layed Out 100
we were planning on spliting the back fenders horizonaly and adding three inches in the middle from extra fenders.
Old Jul 3, 2008 | 06:00 PM
shammaster21's Avatar
shammaster21
couldnt u just raise the bed up to make up the difference?
Old Jul 3, 2008 | 07:29 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Originally Posted by sdetweil
Most of it is driven by the desire to fill up the empty space in the fender wall.
thats why I did the 18/20's on mine.. just didn't go to the extreme..
Sam
I really like the way yours look Sam. Great stance!
Old Jul 3, 2008 | 08:47 PM
brucewolff's Avatar
brucewolff
Sam
Sam, your truck looks great!
But, I have to disagree with you on the notion that you have to increase the rim size to fill up the wheelwell. Usually what happens is you end up with larger diameter rims with rubber band tires because that's all that's available. as you can tell I'm not a fan of rubber band tires on these older trucks. What really has to happen is to determine the tire diameter and sidewall height you what front and rear to give you the "fill the wheelwell look" and the rake you want. Then get the rim diameter for those tires.
Old Jul 3, 2008 | 08:53 PM
Layed Out 100
Yea I'm pretty sure I could do that, but I want to try this out and see what it looks like. I can picture it in my head and I think thats what I really want. I think that would look good from the side veiw but the roll pan was the reason I wanted to go this route.
Old Jul 3, 2008 | 08:56 PM
Layed Out 100
Man thats a good looking truck sdetweil
Old Jul 3, 2008 | 09:35 PM
sdetweil's Avatar
sdetweil
I agree on the process.. I'm not happy about the low profile on the rear myself, but there is nothing between 35 and 50 in 20's.. a 40 would look SO much better, and give that little extra fill, and bump room..
50's at this size are gargantuan, 6 in sidewall. vs 4.35 on the 35 profile, and they would be 32 in tall.. vs the 28.7 now.. that 3+ in is HUGE..
using the sizes I have, the sidewalls are within 1/10th in of each other. (aka same)
I spent a lot of time using discount tires size calculator trying different combos.
I was going from 15 in to 20 in, so that is +2.5 lift in the rear.. the 3.5 in tire size dif would have added ANOTHER 1.75 inches..
(and I didn't want the truck to look like the image of the one with the 22's in the rear, nose dived into the street.!)
the fronts went from 15 to 18, so +1.5 in lift..sidewall about the same as the 15s.
here are the 315/35/20 and the 305/50/20, as I was trying them on before ordering tires & wheels. the 315/35/20 actually look a LOT better than the prefit pic forecasts.
and the actual view, straight on
Sam
Old Jul 4, 2008 | 06:25 AM
GreatNorthWoods's Avatar
GreatNorthWoods
there is a dallas craigslist F100 with 22s
'55 Ford Rat Rod - Sell or Trade for motorcycle, travel trailer, ATV
Sam
Dang, that think reminds me of an old west buckboard with wagon wheels...
Old Jul 4, 2008 | 07:59 PM
56efffie's Avatar
56efffie
The three inches would help from a width standpoint , What could you do so the top of the tire doesnt hit the top of the fender before the truck hits the ground? The only thing i can think of is to move the fenders up 2 to 3" from their current position.
Old Jul 4, 2008 | 10:00 PM
  #28
Layed Out 100
Something like this
Old Jul 4, 2008 | 10:06 PM
  #29
56efffie's Avatar
56efffie
OK, I see where you are going, that works too. That should give ya plenty of clearance to tuck those tires.
Old Jul 4, 2008 | 10:15 PM
  #30
Layed Out 100
yea....just worried about the front, may do 20s on front and 22s on rear. Just have to get to that part of the build. I believe if I do that it wont look like a donk. just have to wait and see and if it does I will change it!
50adrod
Feb 18, 2011 09:53 PM
rostena
137
Sep 1, 2008 07:20 PM
MisterCMK
24
Dec 13, 2006 07:22 AM
