hard cold starting
Old Jul 1, 2008 | 09:04 PM
jeepdude's Avatar
jeepdude
hard cold starting
Newbie here... Just purchased an 01 f-350ps. Have had it about 3 weeks now. Went out to start it this morning and it cranked over good but wouldn't start. Was making a strange clicking noise under the dash to the right of the fuse panel. Hadn't heard that before. Went back out an hour later and it started without the clicking sound. If you let it warm up it starts great without the clicking noise. I'm showing 14 volts on both batteries while it's running. Noticed I had a 20 amp fuse blown also but it started without replacing it at the moment. Runs great though. I also own an old 86 f-350 w/ a 6.9. This 2001 is so much nicer to drive. Thanks for any help.
Old Jul 1, 2008 | 09:21 PM
guitarpicr's Avatar
guitarpicr
Sounds like it might be the relay for the injectors. Someone will be along that knows the number for you. This will bump you up to the top. Would try to locate that relay. Look in the owners guide for the location.
Old Jul 1, 2008 | 09:29 PM
jeepdude's Avatar
jeepdude
Looked in the glovebox... no owners manual, was going to check what that 20amp fuse I replaced went to.
Old Jul 1, 2008 | 09:37 PM
megawatt00's Avatar
megawatt00
Welcome to FTE Jeepdude. Do you know how old the batteries are? If they are week they may have enough juice to turn over but not fire. Does this happen if the truck sits for a while? Like overnight then it is ok all day? Also check all connections make sure that they are clean and tight. How is your oil? Clean and full?
Old Jul 1, 2008 | 09:46 PM
jeepdude's Avatar
jeepdude
Not sure on the age of the batteries, they might be originals... they are motorcraft. 12.66 volts on both non cranking, I'm by myself at the moment so I can't check them while they are cranking. Terminals are clean. Overnight, Yes. Last night was the 1st time this has happened. I waited about an hour and tried again and it started. Oil is clean and within operating range.
Old Jul 1, 2008 | 09:50 PM
megawatt00's Avatar
megawatt00
When you checked the voltage on the batteries was it shortly after the truck was running? Or after sitting for quite a while?
Old Jul 1, 2008 | 10:10 PM
jeepdude's Avatar
jeepdude
About 4hrs later. I guess I might know a little more in the morning. If it does the same thing I'll try jumping it. Just seemed kinda strange that clicking sound under the dash... only when it was just cranking and not starting.
Old Jul 2, 2008 | 07:26 AM
jeepdude's Avatar
jeepdude
Checked voltage this morning before trying to start. 12.57 on one and 12.66 on the other battery. It started up 1st try, I shut it off 10 seconds later and tried again. Had that same clicking noise and no start. It took several more attempts of cranking before it started.
Old Jul 5, 2008 | 02:17 PM
jeepdude's Avatar
jeepdude
It happened again today, had my wife crank it over while I checked battery voltage. One had 9.3 volts and the other 8.2 volts. Doesn't sound sufficient to me. Anyone else???
Old Jul 5, 2008 | 02:24 PM
megawatt00's Avatar
megawatt00
That is way to low to fire off the truck. I would start by getting 2 new batteries. When you install them make sure that all the connections are clean and tight. As an added precaution I always coat my terminal with Noalox then put the clamps on, followed by a light coating on top. This will help to stop any corrosion.
Old Jul 5, 2008 | 02:46 PM
zx250's Avatar
zx250
Of the next Riffraff East
Jim is on target. the clicking it relays making/breaking due to low voltage. I would also suggest you have you alternator check just make sure you problem is not there. No batteries will last with a weak alternator.
Old Jul 5, 2008 | 02:52 PM
jeepdude's Avatar
jeepdude
I'm assuming they are original , being they are motorcraft batteries, unless of course serviced by a dealer. Don't see any knock off date tags on them either.
Old Jul 5, 2008 | 03:04 PM
zx250's Avatar
zx250
Any thing less than 10.5volts will not start our trucks. Less will cause the PCM to reset. Be sure and replace both batteries with same type of heavy duty batteries. Several good batteries out there and some thats not so good.
Old Jul 5, 2008 | 03:29 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Jeepdude - where are you located? Mind filling in your profile? That way if you need more than just an online answer one of the faithful can jump in there. You'd be amazed at the incredible group of people in this forum.
siredward20
16
Oct 6, 2013 09:43 AM
Gonu50
1997 - 2003 F150
Mar 9, 2013 10:07 AM
jpkinard
27
Sep 30, 2012 06:30 PM
noster75
1997 - 2003 F150
Dec 10, 2009 07:50 PM
DKdude
Jul 9, 2007 12:29 AM
