Fuel Sediment Water Switch
Old Jul 1, 2008 | 04:55 PM
timcos's Avatar
timcos
Where is the Fuel Sediment Water Switch? (That's what it is called on the wiring diagram).
My dash light is on and does not go off...do not know if switch is bad or there is something clogging it, or what.
Tim
Old Jul 1, 2008 | 11:28 PM
George D.'s Avatar
George D.
What year is your truck?
Old Jul 2, 2008 | 12:46 AM
goodB0Y's Avatar
goodB0Y
On my 91 7.3 the water in fuel light ( I think this is what your talking about) sender is located below my fuel filter, left front of the engine as you look at it from the front...I would think that they aren't all the same but thats ware mine is.
It lights up if there is water present in the filter...water is no good for a desiel, lol. on my truck there is a drain valve at the bottom that I can open to drain the water if any. I think there's a procedure to drain it properly, but I don't know it. I allways open it up and drain the water and allways end up with air in the system and it runs rough for a bit and then clears up, hope that helps :>)
Old Jul 2, 2008 | 03:02 AM
goodB0Y's Avatar
goodB0Y
don't want to hi-jack this thread but anyone know if there is a "proper" way to drain the seperator... maybe with the engine running?
Old Jul 2, 2008 | 03:46 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I may be wrong but I've always just drained it out the bottom, even on my Cummins. If there's a different way I don't know of it.
Old Jul 2, 2008 | 06:53 AM
timcos's Avatar
timcos
I have a 1984 F250 6.9 diesel. And yes the fuel filter is on the front right of the motor.
Old Jul 2, 2008 | 09:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
On the 84 the water seperator, if the stock one is still on the truck, is located on the firewall between the drivers side hood hinge and the brake booster.
Pull ring on the top.
The old style water seperators were famous for leaking air into the fuel system, many have been replaced.
If yours is still there, shove a bolt in the drain hose after you drain it, so it does not let air in.
Yours also may already have a bolt in the drain line, so you may need to remove the bolt before you can drain it.
Drain with the engine off on the old style system.
Old Jul 7, 2008 | 05:47 PM
timcos's Avatar
timcos
OK...I found that...plug on top was pretty contaminated...so I at least cleaned it out...and of course the top of the filter was filled with pine needles compost (used to be something) and dirt...all clean now as well.
Old Jul 7, 2008 | 09:56 PM
Dave Sponaugle
Did the light go out after draining the seperator?
Old Jul 8, 2008 | 07:27 AM
timcos's Avatar
timcos
I did not reinstall the dash yet...still trying to get that small fist sized mud dauber's nest out of the passenger side air duct....but I will certainly let you know.
The plug I was referring to was the electrical plug. The "plunger" or release operated just fie and I pulled it and and released a few times.
