buying i beams
Old Jul 1, 2008 | 12:41 AM
juchertf100's Avatar
juchertf100
buying i beams
can anybody tell me which drop deams i should buy for my 66 which manufacture would be best from other experince which would be the best im looking to buy in the next month and have heard things like tie rods brackets dont fit and more work than they are worth .iguess im looking to bolt right up if possable this is my first project and short on cash so i want to do it right the first time
thanx paul
Old Jul 1, 2008 | 07:34 AM
White97's Avatar
White97
I have the DJM beams. No miles on them as the truck is undergoing a near complete tear down. I bought my front beams from Summit. The package they sent had two driver side beams. I contacted DJM and they shipped the correct passenger side, arranged pick up of the wrong part and then sold me the rear drop for a discount to make up for the mistake. Went in without a hitch.
If you buy from Summit you can apply for their credit card and get interest free payments for about 6 months.
Old Jul 1, 2008 | 09:29 AM
White97's Avatar
White97
paul - I forgot to say that when I did the drop I did the disc conversion, new springs, brakes, wheel bearings, the works. And everything was cleaned and coated in POR-15. So I wasn't messing with 43 year old gunk and rust. The rear drop is still in the box. I plan on lifting the bed off to do the rear tank and swap in the rear end from my 74 donor, so I'll install then.
Old Jul 1, 2008 | 11:07 AM
juchertf100
so as far ar the instalation of the ibeams was it pretty smoth and how did the truck look pretty low i hope
Old Jul 1, 2008 | 11:08 AM
juchertf100
what year did you get your disk assb. from
Old Jul 1, 2008 | 12:40 PM
White97's Avatar
White97
I bought a 1974 f100 for a donor ($500). Sold off $200 worth of parts so far and got everything I need for the disc, PS, and rear swap. Can't really tell how low the 65 is because it is up on dollies so I can swing it around in the garage, and the front clip and engine are out, so the front suspension is uncompressed. I got the beams, added the spindles from the 74, put in new king pins (you need a tool - I was able to borrow one), then lifted in as one unit. You should really look to do the disc conversion at the same time.
Old Jul 1, 2008 | 12:44 PM
juchertf100
ive got the ibeams disks and springs from a 74 f100 2wd thats why i was asking now when i buy the i beams do i get the one for the 74 or my 66 cause the disk conversion is from the 74
Old Jul 2, 2008 | 06:04 AM
White97's Avatar
White97
it's all the same, thats what makes the disc swap using the donor beams so easy. The DJM beams are specific to each side as the end piece of each beam is angled back towards the cab, the factory beam is straight up where the spindle mounts. VEry easy install, tie rod extenders were the hardest part and that is only because you don't have a lot of travel with teh wrench when installing. I did file the edge of each extender a little to remove the sharp edge which gave me a little bit more travel on the wrench.
Check out my gallery I posted some pics
Old Jul 3, 2008 | 11:08 PM
yotee's Avatar
yotee
thats funny, i've been lookin for the 3" drop i beams, and been saying no on all the internet $650 + prices and saw this thread and they are only 585 to my door from summit. they are ordered and on back order but should be here in 2 to 3 weeks. i would have never thought to look at summit for them if not for this thread.
mike
ps more to come when i get them.
Old Jul 3, 2008 | 11:22 PM
juchertf100
keep me informed on how it goes
paul
Old Jul 4, 2008 | 12:52 AM
yotee's Avatar
yotee
paul
i'll update my gallery and update my "hello" thread.
Dino195
1997 - 2003 F150
Jul 31, 2012 10:18 AM
99FORD EXPY.
13
Jul 31, 2011 08:12 PM
cheapestdeal
Canadian National Chapter
Jan 9, 2010 12:11 PM
AdamBailey
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 29, 2007 06:35 PM
Wej
Jul 25, 2002 04:28 PM
