E3 Spark Plugs
Old Jul 1, 2008 | 05:02 PM
alxsnmr's Avatar
alxsnmr
100K in the block is real attractive if you have to cut holes in the fender wells/firewalls to get the plugs out. I rather like the new placement of plugs with the DOHC engines, straight down from the top with an extension is better than leaving half your knuckle on the frame or exhaust manifold.
Old Jul 1, 2008 | 05:55 PM
quicklook2's Avatar
quicklook2
dohc plugs get stuck also.
i have a lincoln town car that had both rear plugs stuck in and i had to soak and heat them to get them out.
Old Jul 2, 2008 | 01:46 AM
TexasGuy001's Avatar
TexasGuy001
If you want good plugs just get Motorcraft or Autolite spark plugs.
I think that since E3 is a sponsor they rigged the results to show that it is better.
I agree all of those types of plugs are useless. The current will take the path of least resistance anyway. So if it has 2 3 or 4 tabs it doesn't matter.
oblivionnewtonjohn
24
Feb 12, 2015 06:34 PM
TomFL
Nov 4, 2014 09:10 AM
TexasLonghorn75
2004 - 2008 F150
Nov 26, 2013 12:18 AM
deanjet
Mar 9, 2010 07:28 AM
pintoches
Aftermarket Products
May 6, 2009 12:18 PM
