CCV mod cloud.
Old Jun 29, 2008 | 07:05 PM
natewoz's Avatar
natewoz
CCV mod cloud.
Hi guys,
I had my truck parked with the low sun one one side, and me on the other. with this lighting, I could see a thin whispy cloud of white smoke that was much larger than the truck in overall size. It was thin enough that I have not noticed it before, and would not have seen it without the lighting from the sun.
My CCV exits at the driver side at the rear axle. The odor is very pronounced when working around the rear of the truck, especially when hooking up trailers. I know the odor is to be excessive, but do you guys smell it all the time around the rear of the truck, and that strong?
Does this seem exessive to you guys? Thanks
Old Jun 29, 2008 | 07:14 PM
jhand124's Avatar
jhand124
Yeah it stinks, and I get a big cloud too.
Old Jun 29, 2008 | 07:46 PM
F350-6's Avatar
F350-6
If you're not burning a bunch of oil, and it takes just the right kind of light to see it, then I'd say. yes it's normal. If it's puffing like a steam engine, or you don't have anything at all coming out of it, then it's time to worry.
Old Jun 29, 2008 | 07:56 PM
natewoz's Avatar
natewoz
I've had the truck for 25k, I burn a quart every 2500-3000 miles or so which seems to be normal for these engines.
Old Jun 29, 2008 | 08:03 PM
F350-6's Avatar
F350-6
I don't think you have anything to worry about then.
Old Jun 29, 2008 | 08:27 PM
F250_'s Avatar
F250_
Normal. Not to worry.
Old Jun 29, 2008 | 08:46 PM
natewoz's Avatar
natewoz
Cool, guys. Thanks! Just a little unnerving seeing that cloud, especially since the big CAT's and Cummins engines in the Kenworths I drive at work hardly leave a puff and I never smell it.
Old Jun 29, 2008 | 08:54 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Guys, I have posted this before, I will not do the CCV mod. WHY? Keep your engine clean, and you don't have any smell or smoke coming out of your truck while running in the shop. This is the only mod that I question.
Old Jun 29, 2008 | 09:39 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Rick, Im sure you know this, but the CCV is to keep the intake side clean of the oil.
The smell isn't that unpleasant to me. And It aint near the smoke that the sCummins in my fire truck makes.
Old Jun 29, 2008 | 10:34 PM
miller_feed
I know Joe. I guess I will have to take my IC out and see how much oil I have in it. My truck is close to 8 years old, so that may tell the story.
Old Jun 29, 2008 | 11:02 PM
big poppa's Avatar
big poppa
Didn't do my ccv yet either, a little worried about the pressure thing with the O-rings. I have everything down stairs needed to do it though.
Old Jun 29, 2008 | 11:17 PM
jhand124's Avatar
jhand124
You shouldn't have any pressure problems if you keep the hose short. Mine froze this winter, so I shortened it. It terminates at the firewall.
Old Jun 29, 2008 | 11:29 PM
big poppa's Avatar
big poppa
Thats cool Jason, been reading Guzzles and what you guys have said. Prolly do it soon..
Old Jun 30, 2008 | 09:27 AM
superduty4x4's Avatar
superduty4x4
How did it freeze?
Mine ends under the cab on the driver's side... I'd like to put a filter on it just so that when I'm loading my girls in the truck I'm not getting that stuff blowing all around me and into the truck. When I drop my tank I need to re-route it too.
Old Jun 30, 2008 | 09:51 AM
Mike F250's Avatar
Mike F250
I ran a short hose for the potential freeze issue. A few short trips, sub-zero weather. Having grown up in Minnesota, I could see how it could happen.
