highboy transfer case brace
Old Jul 3, 2008 | 01:37 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by crewcabwannabe
does anyone have a picture? Is this a 'bar' that runs parallel to the frame towards the rear? Don't have one on my truck.. maybe I could just fab one based on a picture.. thanks
There's some pics of the brace in this thread here...https://www.ford-trucks.com/forums/7...hboy-fans.html
Old Jul 3, 2008 | 04:16 PM
flcracker9's Avatar
flcracker9
Originally Posted by montana_highboy
Is your brace riveted to the frame? that would certainly indicate it's factory if it is.
My brace is attached to 2 brackets, one on each end. The transfer case end, is attached to a bracket that is bolted to the bottom of the transfer case. The other end is attached to a bracket that is bolted to a crossmember between the frame rails. I can't swear it came like that from the factory, but I can say that neither bracket looks home made.
Old Jul 3, 2008 | 04:43 PM
montana_highboy
At least you have a brace, a brace is a brace, not that it matters but i'm pretty darn certain the braces that came factory had the bracket riveted to the crossmember, i know some guys retrofit a brace and bolt that bracket to the crossmember, i'd still like to know why i see these braces on EVERY automatic highboy and only a very few of the manual highboys, it the guys with braces on their manual highboys would chime in and say if that bracket is bolted or riveted to the crossmember it would be interesting to see.
Old Jul 3, 2008 | 07:41 PM
Speedshifter's Avatar
Speedshifter
My 77 4spd has the crossmember and the bracket is riveted on.
Old Jul 3, 2008 | 07:58 PM
flcracker9's Avatar
flcracker9
I just looked at the link with the red hi-boy, and my transfer case bracket is exactly the same as the one in that picture. The picture doesn't show the crossmember bracket, but mine is definately bolted onto the crossmember. It's feasable that a prior owner of my truck, grafted a factory bracket onto my truck using bolts?
Old Jul 3, 2008 | 08:29 PM
montana_highboy
Speedshifter says his manual highboy bracket is riveted to the crossmember, so that would indicate a factory install, maybe they were standard equipment on automatic highboys and were an option on manual highboys? i dunno?
Old Jul 3, 2008 | 11:15 PM
bucks77ford's Avatar
bucks77ford
My 77 originally was a manual transmission and I'm putting in a C6. Do I need the brace??
Paul49
39
Jul 14, 2012 12:41 PM
rakent
Feb 21, 2010 05:16 PM
ozzy460
Offroad & 4x4
29
Apr 6, 2008 07:14 AM
ozzy460
Sep 11, 2004 07:06 PM
Patrick_PDX
Jul 15, 2004 11:05 PM
