Offroad & 4x4
highboy transfer case brace
Old Mar 28, 2008 | 09:57 PM
ozzy460's Avatar
ozzy460
i'm having prob with my t case binding up in the deep mud, divorced case, the case is loose and i need to drop it anyways, my questions is, will i benifit from a brace from the case to the frame, like some came with stock? and would i benifit at all from removing the rubber spacers and making them solid?
Old Mar 28, 2008 | 10:01 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
I think the transfer case needs to move a LITTLE bit hence the rubberspacer, i would check to see how soft those spacers are as i know there supposed to be rather hard actually. If there rotter or something they could be real soft, letting your tcase move and bind.
JMO
Old Mar 28, 2008 | 10:11 PM
ozzy460's Avatar
ozzy460
oh they're real loose, i can push the case up bout an inch or better
Old Mar 28, 2008 | 10:20 PM
Truckin4life
yea not good, are you sure there tightened down? Are the threads stripped out? Or is it the rubber flexing? If its the rubber replace with new, should be much stiffer, if the rubber is still hard, make sure everything is tight and not stripped out.
Old Mar 28, 2008 | 10:46 PM
captain p4's Avatar
captain p4
Yeah, I'd think replacing the bushings should solve your problems. I guess you COULD solid mount it, but you'll get a lot of vibrations and might end up breaking them.
Old Mar 28, 2008 | 11:27 PM
chrono4's Avatar
chrono4
You probably don't want to solid mount it. It would transmit alot of gear noise I would think, and you want it to have SOME give to absorb shocks.
Old Mar 29, 2008 | 12:02 AM
Slow's Avatar
Slow
Don't listen to them! hehe.. there's nothing in there to vibrate.. unless there's something wrong with your shafts. I solid mounted mine with a custom cross member and it's been fine. I see in your sig you are running 38" tires.. like me.. they create more vibration than anything in the driveline possibly could .
I should also mention that in the winter I run smaller radials to run around town in and there's no vibration in the drivetrain to speak of that I can feel.
Another with it in, but not everything hooked up yet:
This has nothing to do with this thread really, but here's the side shot.. the t-case is 1/2" from the cab. I guess a guy could make a recess or somehow clock the case, but for now, this is good.
Old Mar 29, 2008 | 12:05 AM
captain p4's Avatar
captain p4
hey listen to the guy that's done it before, I was just suggesting what I know works - nice truck, btw!
Old Mar 29, 2008 | 12:07 AM
chrono4's Avatar
chrono4
I wasn't posting it from experience, but Ford made them with a bushing for a reason, so I just posted my thoughts on it. Sweet looking rig though.
Old Mar 29, 2008 | 12:14 AM
Slow's Avatar
Slow
Talking
Thanks mate! It's stuck in almost 4' of snow right now though! hahaha. I spent a few hours after work shoveling. I'll have to go back in the morning. It's become clear that I need a winch.. maybe even more than crossover!
Old Mar 29, 2008 | 12:19 AM
captain p4's Avatar
captain p4
4 feet of snow? Where do you live?
Old Mar 29, 2008 | 12:27 AM
bucks77ford's Avatar
bucks77ford
My 77 Highboy didn't have that brace that is being talked about. I've seen it on a few older models. Did they come with all highboys are just some. What's the purpose if not all came out with them?
Old Mar 29, 2008 | 12:32 AM
Slow's Avatar
Slow
Ya I'm not sure on the brace.. wasn't it a front to rear brace? I can't remember now. It seems to me that the cross member is pretty skookem and should be good with the rotational forces. Mind you I just have a wee 300 6, not a 460. If I were you I'd just drop the thing and evaluate. I'd say hard mounting is not a problem and then figure out if you need some kinda brace. If you didn't have one before and it's just the bushings I wouldn't worry about it.
I live in BC canada in the kootenays. This winter has been crazy.. usually there's almost no snow by now but in the mountains, in the shade, in places where you least expect it, you can apparently sink down to the cab and beyond!! ;-) I'm still not sure how I'm going to drive it out even after I shovel enough space to get a run at it.. need to get on top of the snow .. should be interesting..
Old Mar 29, 2008 | 12:35 AM
chrono4's Avatar
chrono4
wow, sounds crazy. YOu should snap a pic of it when you go out there, that stuff has to be insanely deep.
Old Mar 29, 2008 | 06:08 AM
STGFordCrazy04's Avatar
STGFordCrazy04
Snow? It was 82* at my house yesterday. "Cold snap" today so the high is going to be in the 70s
I do remember seeing a brace on Pros truck. Im not sure if its factory or something he built. It was a short piece of tubing that bolted to the rear of the case and angled up towards the frame. Ill see if I can get a pic
