96 F150 4.9 missing/shaking
Old Jun 28, 2008 | 12:54 PM
grobinson's Avatar
grobinson
Truck is missing between 30-40 MPH. Replaced cap,rotor,wires and plugs.
Happens only on acceleration in any gear. Rotated tires thinking i might
have one out of balance.
Did notice that the plugs were a white color, all six the same when i changed
them, and if it has anything to do with it, i did notice a big INCREASE in
milage before the miss started happening.
Old Jun 28, 2008 | 01:00 PM
jesterdog's Avatar
jesterdog
See if you can separate the engine from the driveline. Like, slowly reving it up in park or neutral. Also, how about getting it to shake on the road and letting off the gas, or pushing the clutch in, or slipping into N. Does the noise go away? That would give you data as to whether it is the rolling chasis or engine under load, right?
Old Jun 28, 2008 | 01:07 PM
grobinson's Avatar
grobinson
Sorry, forgot to add that, while acelerating thru the speed range, depressing
the clutch causes the miss/shake to go away, making me believe it is
related to the engine. also, its only under load, coasting or decreasing
speed shows no sign of the miss/shake. Thanks
Old Jun 28, 2008 | 02:01 PM
Ford_Six's Avatar
Ford_Six
It could be an injector issue- is the check engine light on and have you had codes pulled yet?
Old Jun 28, 2008 | 02:48 PM
grobinson's Avatar
grobinson
No check engine light, had scanned for codes, nothing showing. Checked
EGR by applying vac while running. EGR seems to be ok.
Old Jul 4, 2008 | 10:23 AM
jesterdog's Avatar
jesterdog
Fuel filter?
Old Jul 4, 2008 | 12:55 PM
Lead Head's Avatar
Lead Head
So it happens at 30-40 miles regardless of gear? You can be in 2nd, 3rd, 4th or 5th, and still shakes/misses at 30-40?
Old Jul 4, 2008 | 02:58 PM
grobinson's Avatar
grobinson
happens regardless of gear, new fuel filter, both pumps are new. no codes
being set. happens only under load
Old Jul 4, 2008 | 03:09 PM
Lead Head's Avatar
Lead Head
so your saying, no matter what the engine revs at, it still misses/shakes at 30-40. To me that sounds like an off balanced tire, drive shaft or clutch
Old Jul 12, 2008 | 08:50 PM
sldhd7's Avatar
sldhd7
could it be a TPS starting to go bad? EGR opening too much. MAP sensor starting to go bad, not telling the computer to give it more fuel because its having a hard time "seeing" low vacuum under a load. You said the plugs looked lean and you noticed fuel milage going up; some how some way its not getting enough fuel it sounds like.
PS could the screens in the fuel rail be plugged up? have the fuel system cleaned and back flushed.
swebeaux
1997 - 2003 F150
Apr 18, 2011 04:56 AM
brshelton
1997 - 2003 F150
Nov 6, 2004 09:42 PM
ArizonaDPS
3.0L V6
May 27, 2004 06:38 AM
