fuel pump
Old Jun 27, 2008 | 04:10 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
fuel pump
Sup,
I got a 2001 f-250 7.3. After starting today I was leaving the job and noticed a loss of power, I got back to my house (maybe 1.5 miles) and switched trucks. I got back 2 hours later, same thing. Drove it to my friends shop maybe 3- 4 miles (not a diesel dude) and he checked for tsbs etc. It was throwing no codes either.
Finally I convinced him to test drive it 1-2 miles and it died on him, he thinks its a fuel problem.
My excursion had this happen when my sister borrowed it and it was a fuel rail pump? Does the f-250 have this too or is it in the tank? If it is I can fix easily cause I put on a lift bed last fall (awesome)
It is in a retail parking lot and I would love to fix it there w/o towing it. Any easy way to diagnose with out towing to shop.
Thanks
Jo0hn
Old Jun 27, 2008 | 04:23 PM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE....the fuel pump is on the frame rail right under the driver seat....
Old Jun 27, 2008 | 04:36 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Thanks I will test it tommorrow.
John
Old Jun 27, 2008 | 04:44 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Is that the only fuel pump? Not on in the tank? If 2 how do I tell which is bad?
Thanks
Old Jun 27, 2008 | 04:48 PM
HKusp's Avatar
HKusp
Unless someone put another in it, the only one is under the drivers seat. There is a pick-up screen in the tank that could be clogged. I would also check the fuel filter under the hood. When was the last time that was changed.
Old Jun 27, 2008 | 04:51 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It's time i'm sure the truck has 115k on it I change it every 30k so it's close. It started running like crap all of a sudden though and the cut off. I think it's more than the filter. How do you check/ clean the pickup filter?
Old Jun 27, 2008 | 05:58 PM
HKusp's Avatar
HKusp
Drop that tank and take a look. I haven't ever done it on this truck, but I have heard it described. You can check the pump by emptying the fuel bowl and then turn the key to the on position, but don't start it. The fuel bowl should fill up very fast. Less than 5-6 seconds. You can try to blow compressed air through the fuel line back into the tank as well. Just know that you will have introduced a lot of air into the system, so it will take a while for it to work it's way back through the injectors. So after you do the blow through technique, the truck will run rough for 30 or so miles.
Old Jun 27, 2008 | 05:59 PM
HKusp's Avatar
HKusp
Btw, the recommended interval for changing the fuel filter is 15K not 30. Just for future reference.
Old Jun 27, 2008 | 06:39 PM
jhand124's Avatar
jhand124
Won't the fuel spray everywhere, should he put the cap on the fuel bowl and collect the flow from the drain tube?
When is the last time you filled up? Could it be bad fuel? Which may mean the pickup screen has debris or the fuel filter is mucked up.
Old Jun 27, 2008 | 09:24 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I did fill up like 100 miles ago, but it went from runnin like a dream to DEAD in maybe 7miles getting progressively worst each mile.
I don't have to drop the tank cause I got a dump bed.I can see the top of my tank in less than 5 seconds!! But I guess regardless, I need to change the filters in my truck and Excursion. Thanks HKusp for the reminder.
Old Jun 28, 2008 | 11:51 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Got her runnin'
It was the fuel pump, easy fix but a bit meesy in the mall parking lot.
Thanks doods
Old Jun 28, 2008 | 11:55 AM
mueckster's Avatar
mueckster
Glad you got'r fixed!
Old Jun 28, 2008 | 03:45 PM
HKusp's Avatar
HKusp
Originally Posted by Jmatthews
Got her runnin'
Thanks doods
Glad to hear it. Thanks for letting us know.
Jrod Webb
25
Oct 29, 2013 08:24 PM
NMB2
16
Jun 21, 2012 07:50 PM
Hotwheelbill
78
Apr 22, 2007 09:20 AM
dirtracefan73
Oct 16, 2006 09:55 PM
73Custom
Mar 25, 2004 09:33 PM
