Sponsored by: Auxito
Bad GEM? electrical problems!
Old Jun 27, 2008 | 11:46 AM
cuaco-ortiz's Avatar
cuaco-ortiz
Hi, can anyone help me with some problems on my F150 4 door?
The power windows, interior lights and running boards and wipers are out. I have checked the GEM because of the water leaking, and the SOB is dry, no shorts, no nothing, it looks like new.
Can this SOB get damaged by itself?
I have also checked all of the relays related and they are good.
Do I need to replace my GEM? Has anybody replced it with out looking damaged? I would not like to spend alot of money on it to have it give me the same problems again.
Can you buy it on a junkyard from a similar truck and just replace it?
Does it need to be bought new and then reprogrammed at the dealer?
Mine is a 99 with the 5.4L.
Any help at all wopuld be apreciated, thanks...
Old Jun 27, 2008 | 02:03 PM
KingRanchMan02's Avatar
KingRanchMan02
The way that the GEM controls the many things that it controls, is by completing the ground for the circuit. The ground for the GEM is in the drivers footwell, under the kick panel. It will be at the bottom of the A-pillar panel and the wire color is BK/LB. Good luck!
Old Jun 27, 2008 | 03:13 PM
cuaco-ortiz
Thnaks man, I have tried that when I took the GEM off, I took the ground wire off and place it back in, it has 2 wires each with an eyelet that get secured onto the sheet metal.
When I was trying to remove it, it was giving out little sparks, a good sign of ground contact.
Do you think I would need to replace the GEM?
I will try also to bring a gorund wire directly from the battery and connect it to the ground for the GEM, just to make sure.
I'll keep posting...
Old Jun 27, 2008 | 03:23 PM
KingRanchMan02
Did you take the fuse panel and GEM out from under the dash, separate them and look for corrosion?
Old Jun 27, 2008 | 05:24 PM
cuaco-ortiz
I checked the fuse panel and the connection between the GEM and fuse panel, there are no signs of corrosion or running water marks at all. The GEM looks brand new.
What else do you think I can try and fix, i have not have the time to reconnect the ground wire directly onto the battery yet.
schwefel
May 20, 2019 12:26 PM
sabbyone
New Member Introductions
Feb 12, 2010 09:55 PM
pscrow86
Nov 24, 2009 08:19 AM
jimmah
Apr 13, 2008 07:40 PM
Malaxi
Apr 10, 2006 09:35 AM
