Wheel size ?
Old Jun 27, 2008 | 09:45 AM
bcrab's Avatar
bcrab
Question Wheel size ?
SIZE........OFFSET.......BACKSPACE.......TIRE
17x9........-12............4.53".......33x12.5OR17 Discoverer ST
I have a AS 2" level kit on the front. The tire man said there might be an issue with rubbing on the truck because of the -12 offset. He asked me if I had a lifted truck, told him just the leveling kit. Because of the -12 offset, he said it might rub on the knuckle? I've read where some 17's have fitment problems on our trucks. Before I cut my arm off for a set I need to find out if they're gonna fit.
So my ? is does anybody have these rims with the same or similar setup as mine and is there any rubbing?
05 FX4.
Thanks for the help.
Old Jun 27, 2008 | 06:32 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
sorry man, I think you're going to have to test fit.
the new rims should at least have as much backspacing as OEM wheels. if the rims are pushed outward (to edge of truck), then you'll be fine. it's a no go for any rim that tucks in tighter than the OEM wheels
stircrazy05
2004 - 2008 F150
Apr 25, 2021 05:17 PM
Hansen13
2004 - 2008 F150
Nov 12, 2014 02:29 PM
zslagle93
Aug 10, 2014 09:24 PM
cattlerancher
2004 - 2008 F150
Jul 13, 2011 07:01 PM
