Offroad & 4x4
ttb 44 and aussie locker
Old Jun 26, 2008 | 07:38 PM
fballer985's Avatar
fballer985
plain and simple, will a ttb 44 hold up to an aussie used for snow wheeling?
Old Jun 26, 2008 | 07:58 PM
77fordf-150's Avatar
77fordf-150
I'd think so but that also depends on what size tires and motor you are running.
Old Jun 26, 2008 | 08:24 PM
MBBFord's Avatar
MBBFord
A locker in a TTB isn't a good idea.
The aussie locker is about the best lunch box locker I've found, expecially for the price, but the 1/2ton TTB isn't up for a lot of abuse.
It might work for you, but how about a little more info....snow and plowing, wheeling, stock tires, what?
Old Jun 26, 2008 | 08:25 PM
fballer985's Avatar
fballer985
302 and 235/75/15..........im mainly making this a dd and a snow wheeler/sleeper build. dont need to be flashy just get the job done
Old Jun 26, 2008 | 08:26 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Only if you run 44s under it.
Old Jun 26, 2008 | 08:31 PM
MBBFord's Avatar
MBBFord
In that case, if you feel you Need the added traction of a locker, go for it.
Just remember going straight is the easiest on componants with a locker.
IF you turn, you start putting much more strain on steering, joints, etc....
If you do decide to put a drop in/lunch box locker, the aussie locker is a very good choice.
Good luck
Old Jun 26, 2008 | 10:46 PM
fballer985's Avatar
fballer985
thanks mbbford and btw texastech diesel-is that a farmall?
Old Jun 27, 2008 | 11:22 AM
texastech_diesel
Token Redneck
Yup it's a '49 Cub. It's my "offroad" proj right now
You're putting the locker in a 95 150? What kid of tires do you have under it? You should share your truck.
Old Jun 27, 2008 | 04:25 PM
fballer985's Avatar
fballer985
single cab short bed, some m/t and no lift...ill get a pic when i can fangle my gf's camera...have 80 acres to snow wheel and loved it last year but limited because of open f/r but have dealt with spools b4
justcruzin125
Apr 6, 2016 11:47 PM
brehenkel
Ford Truck Parts for Sale
Mar 6, 2016 07:52 PM
BootHill
1978 - 1996 Big Bronco
Jun 7, 2005 01:18 PM
cek181
19
Dec 11, 2002 04:28 PM
Ed Trethewey
Offroad & 4x4
Nov 8, 1999 04:40 PM
