Pleas help. I have a 4.0l flyewheel clutch and starter on my 2.9l V6 Bronco2!
Old 06-25-2008, 12:55 PM
homeandranch's Avatar
homeandranch
homeandranch is offline
I just bought this bronco(2.9l V6). I noticed the starter was staying on for about 2 seconds after the engine cranks. Come to find out the guy who had it before me put on a flywheel,clutch, and starter from a 4.0l '97 Ford Explorer.
I am going to try to shim the starter out to see if that fixes the problem but now I am concerned about using the bigger flywheel and clutch with the smaller engine.
Is this ok? He said he did it because of the bigger tired he had put on the truck. I am a bit concerned now. If it is ok any ideas on how to fix the starter issue?
Old 06-26-2008, 08:38 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
Hi and welcome!
This isn't an issue I've come across before. The 4.0 flywheel would have to be the same diameter as the 2.9, though it may be heavier. I would go ahead and try shimming the starter to see if that takes care of the problem. Does it seem to run okay once it's started, no vibration problems? The 4.0 is basically a stroked version of the 2.9 anyway.
Old 06-26-2008, 10:18 AM
homeandranch
Oh yes it runs great. I am not as young as I used to be and jacked up my back pretty good. Soon as I feel better I am will go shim it out. I will let you know how it turns out.
Thanks
Kronis
48
10-04-2014 02:48 PM
jtindale
10-12-2012 10:07 AM
Aviator2011
Bronco II
05-30-2012 11:34 PM
gatlin04
Bronco II
21
11-23-2008 06:38 PM
sadbroncowner
Bronco II
12-20-2005 10:50 AM
Quick Reply: Pleas help. I have a 4.0l flyewheel clutch and starter on my 2.9l V6 Bronco2!
