17* Hpop Install?
Old Jun 25, 2008 | 12:08 PM
rivrrunner's Avatar
rivrrunner
17* Hpop Install?
found a 2000 17* HPOP for my early 99....is this a straight install swap, and if not any tips???
Thanx in advance
Old Jun 25, 2008 | 12:12 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Yep - straight bolt-on - just one itty-bitty internal part that makes worlds of difference
Old Jun 25, 2008 | 12:36 PM
hucka1a's Avatar
hucka1a
What kind of performance gain can you expect to get by swapping just the HPOP on an early 99? Do you need to get later model injectors?
Old Jun 25, 2008 | 01:13 PM
JoeTrotter's Avatar
JoeTrotter
I havn't done it yet, but you can keep your injectors. If you get bigger injectors, you'll most likely need an even bigger HPOP. I know with just a chip, and stock injectors, I'm always out running my stock pump! I believe most of the performance to be had will be at high RPM's, especially under load.
Old Jun 25, 2008 | 03:16 PM
rivrrunner's Avatar
rivrrunner
i have heard that stock injectors will handle all the 17* hpop can give.......from Joey @ terminator engineering...
Old Jun 25, 2008 | 04:46 PM
farmdad's Avatar
farmdad
Just for a "heads up", if you do the change and your original IPR is working fine, put it into the "new" pump. My son did the switch and the IPR died a couple miles down the road. Towed it back to the shop, replaced the IPR with the original and it's good to go. Runs fine but he had put in single shot injectors and the PCM from a newer year.
Old Jun 26, 2008 | 12:08 AM
rivrrunner's Avatar
rivrrunner
thanx for the "heads up" reps to ya
Ezalycasaid
35
Sep 10, 2016 05:29 PM
fordpride
52
Jan 18, 2012 08:57 PM
jchosler
114
Jul 19, 2010 01:18 PM
chesterstroker
Jan 21, 2009 09:46 PM
mustang_gt_350
Oct 10, 2007 01:58 PM
