Block C6ME-A, Engine identification
Old Jun 24, 2008 | 11:24 PM
dinoking's Avatar
dinoking
I have recently acquired a 1937 Ford 5 window coupe which was an older rod project. It sets on an old Ford truck frame and has a Ford big block power plant with an auto trans. My goal is to find the specifications for the engine. This is the info I have:
Block cast no. C6ME-A, Date code 6H5
Intake man. C7TE9426E 6H4
RH Cyl. head C6AE-Y
RH Exhaust man. C6AE9430-A, 8 bolt, vert. aligned.
LH Cyl. head C7AE-A
LH Exhaust man. C3SE9431-B, 8 bolt, vert. aligned.
Autolite Distributor, C7AF 12127 Y, (5 or 6)H8
Autolite Carb. Tag C7AFAK, B6HB (2 barrel)
Unsure of the tranny model, can't find a number...
The engine is currently stuck, but ran when parked some 25 years ago. I am undecided weather to rebuild this engine or replace it with another.
I am replacing the truck frame with an aftermarket rod frame.
Also what reading material is recommended for identification and rebuild.
Any assistance will be greatly appreciated!
Thank you, Don
Handegard
19
Jun 25, 2011 04:52 PM
Big Skier
Jan 25, 2011 11:36 AM
dinoking
Jun 25, 2008 03:31 PM
spazboz
Mar 29, 2008 09:24 AM
tn.countrygirl
General Automotive Discussion
15
Jul 13, 2007 01:48 PM
