Coolant Shut-off Valve?
Old Jun 24, 2008 | 06:58 AM
StevensPoint's Avatar
StevensPoint
I will be installing a Webasto coolant heater that circulates coolant through the block and heater core. In line between my water pump cover and the heater core there is what looks like a vacuum actuated coolant shut-off valve. Does anyone know the specifics of when this valve is controlled to be open and closed? Could cause problems with my heater if that valve is closed at the wrong time.
Thank You
Old Jun 24, 2008 | 08:06 AM
69cj's Avatar
69cj
That is the heater control valve and it is closed anytime the truck is not running and anytime the heater control is not calling for heat.
Old Jun 24, 2008 | 08:23 AM
StevensPoint
Hmmm.... I think I'll have to remove that. Thanks for the quick reply!
Old Jun 24, 2008 | 11:07 AM
PupnDuck's Avatar
PupnDuck
If you remove the heater control valve you'll have hot water circulating through the heater core when the A/C is running. Your A/C will never run at anywhere close to full efficiency.
Old Jun 24, 2008 | 01:43 PM
StevensPoint
Is this A/C system designed differently than older trucks and cars? Most cars have coolant flowing through the heater core whenever the engine is running.
Old Jun 24, 2008 | 01:45 PM
StevensPoint
Is the heater control valve in all '06 trucks, or just the King Ranch with the electronic climate control?
Old Jun 24, 2008 | 02:34 PM
PupnDuck's Avatar
PupnDuck
The heater control valve is a normally open valve, closed by vacuum; therefore, when the engine is off the valve is open. If you have the electronic climate control the valve is controlled by the climate control and will be driven closed to provide maximum A/C. The climate control system monitors ambient (outside) air temperature, inside temperature and solar load. When there is a need for max a/c the valve is closed to keep hot water out of the core.
Old Jun 24, 2008 | 03:51 PM
StevensPoint
Thank You!
Old Jun 24, 2008 | 04:56 PM
18vtx00's Avatar
18vtx00
exactly it will be like a lot of GM vehicles..fresh air will be 140*F in the summer..I would not take it out althought you may be able to relocate it if it is in the way..
kr98664
Mar 1, 2016 04:03 AM
ddeflyer
May 31, 2015 04:35 PM
OSHS
13
Jun 19, 2014 05:56 AM
68cabby
18
Jan 7, 2013 08:52 PM
Steves55
27
Jun 21, 2010 06:14 AM
