Heater Shutoff Valve?
Old Feb 29, 2016 | 12:35 PM
kr98664's Avatar
kr98664
Greetings,
I'm looking for a part number for adding a 4 port vacuum controlled shutoff valve in the coolant lines feeding the heater. Preferably, I could pick one up at my local NAPA. I could have sworn I had seen such a post in this forum, but I can't find it.
A few years ago, I added a 2 port shutoff valve (NAPA #660-1200) and it worked great, but it completely shuts off coolant flow in the heater circuit. I now realize a 4 port version would be better, as it would return the coolant instead of completely stopping the flow.
I'm looking for a valve that diverts the flow when vacuum is applied, and runs straight through when vacuum is released.
Thanks
Old Feb 29, 2016 | 12:50 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The four port 5/8" vacuum control valve from mid '90's Rangers is F87Z-18495-AA.
I'm not sure what the Motorcraft # is.
*edit* yg350
((( YG-350 )))....
Old Feb 29, 2016 | 01:13 PM
kr98664's Avatar
kr98664
*edit* yg350
Thanks! That translates to BK 6601294 at NAPA, for anybody else in search of this valve.
Old Feb 29, 2016 | 01:37 PM
4x484150's Avatar
4x484150
Here is another thread on the subject. I knew I saw this question somewhere else!
Old Feb 29, 2016 | 01:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
*edit* Motorcraft YG-350
F87Z-18495-AA (Motorcraft YG-350) replaced F4TZ-18495-A & B; F5TZ-18495-A
Old Mar 1, 2016 | 04:03 AM
dtgl90vt's Avatar
dtgl90vt
I tried a 4 port for awhile, it ended up leaking coolant out the vacuum line. So I switched to a 2 port and have noticed any issues yet. Also keep in mind the 2 port was available on the vans, so I figured it was capable of the same duty as the trucks.
Devin
spicolas
Aug 8, 2014 08:43 PM
Poolguy601
Dec 25, 2012 05:20 PM
LastStarfighter
1983 - 2012 Ranger & B-Series
Nov 24, 2012 03:22 PM
jeep.hauler
May 25, 2010 04:24 PM
peganit2
Aerostar
Jan 27, 2009 05:27 PM
