Rear door locks
Old Apr 1, 2017 | 12:44 AM
Thumper911's Avatar
Thumper911
Rear door locks
I've noticed that if you use the interior handle to open a locked door, the door unlocks and opens without using the unlock button. This only seems to work on the front doors. The rears need to use the unlock button to unlock them before the handle will open the door. Seems strange that the rear doors don't behave the same way.
Old Apr 1, 2017 | 01:01 AM
Desert Don's Avatar
Desert Don
Do the '17's have a "child safety switch" somewhere on the rear doors? Some vehicles are equipped with them, and in the "safe" position will act the way you describe.
Old Apr 1, 2017 | 01:38 AM
Thumper911's Avatar
Thumper911
I checked the child safety locks. They are off, but nothing changed in either position.
Old Apr 1, 2017 | 08:06 AM
bridge's Avatar
bridge
Sick 'n Tired
Sounds like an additional child safety feature. If the child door lock switch is on you can't open the rear door even if it's unlocked. It must be opened from the outside.
Old Apr 1, 2017 | 01:37 PM
e23barton's Avatar
e23barton
My rear door locks don't unlock from pulling the inside handle either. This is a major annoyance as I shouldn't have to unlock the doors just so the rear passengers can get out. I checked the child locks and they are not on. Hopefully someone figures out a Forscan option or it gets fixed when I go in for my first oil change.
Old Apr 1, 2017 | 02:34 PM
Sleepyguy's Avatar
Sleepyguy
Change the truck options so it unlocks all doors when exiting or opening?
I do not like how rear doors lack a touch sensor. The tailgate has it why not all the doors...
Old Apr 1, 2017 | 02:49 PM
Thumper911's Avatar
Thumper911
My 2011 Yukon would unlock the doors if you shifted into park. That would solve the problem for sure. I don't think we have that option on the SD though
Amr091078
Oct 17, 2018 05:27 PM
e23barton
Jul 28, 2017 06:11 AM
BigBlueX
Apr 6, 2016 10:33 PM
outlawdakota
Sep 14, 2007 11:25 AM
