1998 e-350 engine swap nightmere
Old Jun 22, 2008 | 11:24 PM
jeremy53402's Avatar
jeremy53402
Here goes... I just finished swapping out the blown 7.3 from my 1998 e-350 limo coach. I installed a junk yard 1997 f-250 engine. everything is in and now I can't get it to run. I know very little about Ford diesels, actually diesels all together cause I've only owned Dodge diesels and never had any problems.
I can't find anyone that seemed to be having the same problems. Two obvious problems are the wait to start light doesn't come on. Also the initinal check engine light does't come on. I was able to get the wait to start light on by jumping the GPR. I had two different guys with some experence with 7.3 come over and try figuring out what the problem is and they came up with these theories: 1.Clearly the injectors are not being engauged 2.It seems that power is not getting to the computor or possibily also the fuse box under the dash.
I can clearly see that I have an electrical problem. I just don't know where to start to eliminate things and get to the source of the problem. I don't know weither it was something I did wrong on the install or it has something to do with to year difference and F-250 to E-350 conversion. The only difference I came into was the wire harness from the origional engine had 2 extra wires that went to a pigtail on the GPR. Where the F-250 only had the 4 wires on the GPR.
Any help?????????????????????????????????????
Please...
Old Jun 22, 2008 | 11:59 PM
Fomoko1's Avatar
Fomoko1
Welcome Jeremy, you`ve come to the right site, you`ll get the answer by posting an inquiry in the diesel forums which you have already spotted.
Be sure to join in your local WI chapter: Wisconsin Chapter - Ford Truck Enthusiasts Forums
anderson123
New Member Introductions
Jul 18, 2016 04:15 PM
horseshoer101
May 1, 2014 08:50 AM
BryanRR59
Apr 16, 2008 07:26 PM
t.duris
May 12, 2007 11:48 PM
