Sponsored by: Real Truck
Road Bounce
Old Jun 22, 2008 | 02:19 PM
zxkeller's Avatar
zxkeller
Road Bounce
I have a F350 for towing a fifth wheel trailer. My truck is fitted with airbags for the load. When I am driving with nothing behind me I get the most annoying bounce. It almost makes you want to stop its so bad. What can I do to this truck to eliminate this? Your help will be appreciated.
Old Jun 22, 2008 | 02:35 PM
zx250's Avatar
zx250
Of the next Riffraff East
How much pressure is in you air bags while empty?
Old Jun 22, 2008 | 02:48 PM
bneafus's Avatar
bneafus
Is it on concrete highways?
Old Jun 22, 2008 | 11:18 PM
zxkeller's Avatar
zxkeller
I usually carry @50 psi. Sometimes it's on concrete road. Once around Oxnard California I almost had to pull over it was so bad.
Old Jun 22, 2008 | 11:54 PM
c.f.moore's Avatar
c.f.moore
I use air bags on my F350. 30-35#s while towing (2650#ppin weight), 5#s when not towing. Tires at 80 psi while towing, 50 psi when not.
Air bags at 50 psi with no load, takes most of the flex out of the rear suspension. Very rough ride.
Old Jun 23, 2008 | 07:04 AM
zx250's Avatar
zx250
Well, there is your problem. You have to let them down when running empty. Drop to 10psi or less and I guarantee you that you will see a huge difference. 50psi is pretty much eliminating your shock and springs when empty.
Old Jun 23, 2008 | 12:59 PM
caprang's Avatar
caprang
When empty I run mine at 5 psi and dont feel any difference at all compared to when I didnt have the air bags installed. I run 30-40 psi when loaded and if I forget to air them down after I unload I can feel the difference on the very first bump I hit. You didnt mention if it was a dually or not but my experience with past dually's was that they rode better with a load, even with no air bags at all.
Old Jun 24, 2008 | 01:01 PM
zxkeller's Avatar
zxkeller
Man,I guess that's what's wrong, way too much air in the airbags. Gonna go out now and bleeed them off.Thanks a lot guys,my first time with airbags!
