ATF change
Old Jun 22, 2008 | 01:52 PM
kevin.ford-trucks's Avatar
kevin.ford-trucks
ATF change
According to the book, the fluid only should be changed every 30K, and then filter at 150K.
I really don't want to do more than necessary, but also don't want to significantly shorten the life of my tranny.
It's got 65K on it now. What should I do? ( I have seen the ATF flush procedure, and was planning to follow that without the filter change).
Thanks,
Kevin
Old Jun 22, 2008 | 07:33 PM
Monsta's Avatar
Monsta
Sit. Stay.
While it doesn't hurt to change the filter it does add to the cost & time of the tranny service. If money is tight then just do the FULL fluid swap via a flush.
However, your tranny has drain plugs for both the tranny & torque converter. This simplifies the drain & refill procedure significantly. So much so, that I would suggest doing it yourself and dropping the pan to change the filter.
Old Jun 23, 2008 | 01:13 AM
kevin.ford-trucks
Would you still do the flush procedure? Or if I drain pan and TC is that enough?
Old Jun 23, 2008 | 02:28 AM
Monsta's Avatar
Monsta
Sit. Stay.
Once you drain you really don't need to do the flush. Most of us have to do a flush because our TC doesn't have a drain plug.
Old Jun 23, 2008 | 07:35 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The flush will change about a quart or so more fluid than just draining the pan and torque converter.
Old Jun 23, 2008 | 11:42 AM
Paul T's Avatar
Paul T
I do not know about a flush in an Excursion, but in the Caddyinfo Forum I frequent for my Cadillac Deville the message is do not ever flush the transmission. Most people that flush their transmissions in Cadillacs experience transmission trouble with in a year. Also a GM engineer that developed the Northstar did not recommend flushing. His concern was that if the flush machines were not cleaned properly they could introduce the contaminants from the last flush into your transmission. Just drain and fill. I did that with my 96 F250 but you only get 1/2 the fluid out because you can not get the fluid out of the torque converter. I would not recommend a flush.
Old Jun 23, 2008 | 12:53 PM
2003 EXCURSION's Avatar
2003 EXCURSION
Which vehicles/transmissions have plugs in the torque converter and which do not? More to the point .... Does mine??? Thanks!
Old Jun 23, 2008 | 01:12 PM
kevin.ford-trucks
The "flush" here refers to an article Mark wrote-up for the FTE folks. Great article. I'm just looking to short-cut a bit at the very slight risk that I don't do quite the same thorough flush as Mark describes. But in terms of a commercial flush - I agree - I'd rather do nothing in most cases than risk someone doing something wrong.
Given that I may leave 1 Qt of old fluid out of about 18 total Qts, I think I'm pretty happy just to drain the pan and TC. And with the pan empty, I may spend 30 minutes to drop it and replace the filter even though it's not likely to be needed. It will give me a sense of how the tranny is running since I bought it used about 9 months ago.
I assume the TC plug on the Ex is in about the same place as it was on my '97 F150. That was simple enough. I do recall one uncertainly -- how tight to put the plug bolt back into the TC. Is there some spec on that? The plug originally had thread lock on it, but there's no way I can get the threads dry enough to reapply. How tight should I torque it? It seems it's one of those that could strip out fairly easily..
Old Jun 23, 2008 | 01:33 PM
Paul T's Avatar
Paul T
I would not change the transmission fluid unless it is discolored or smells bad. Transmission fluid should be red not brown. My 96 F250 fluid was brown and really smelled bad. I had used it to do a lot of towing and neglected to check it regularly. If it is red and not dirty I would not change it.
Old Jun 23, 2008 | 02:02 PM
Mark Kovalsky
Ford put torque converter drain plugs in almost all rear wheel drive transmissions until August, 2001. Any torque converter built after August, 2001, does not have a drain plug in the torque converter.
Old Jun 23, 2008 | 02:05 PM
kevin.ford-trucks
Paul T - yeah good point. But color and smell are subjective. Fresh ATF is bright - cherry juice - red. But over time is gets darker. So the question is when is it "brown" enough to change? I think I'll change every 30K unless it "seems" like it's time to change sooner. I don't do much towing.
Old Jun 23, 2008 | 02:09 PM
kevin.ford-trucks
Mark,
Why did they stop? Just curious. And could a guy drill and tap a plug? Or should I forever buy pre '01 trucks?
Old Jun 25, 2008 | 05:17 PM
topdog5's Avatar
topdog5
hi guys topdog here got a question on transmission fluid what is the best fluid to use in a 2000 v-10 just reg atf fluid or something better I dont haul heavy stuff right now but i do have 10 horses and might need to pull a horse trailer with three or four horses in it at sometime
Old Jun 26, 2008 | 07:16 AM
Mark Kovalsky
Any fluid with a MERCON V rating will be fine.
Old Jun 27, 2008 | 02:43 AM
kevin.ford-trucks
Re: Mercon V -- mine says regular Mercon.
