Radio Removal
Old 10-07-2001, 09:28 PM
jim99's Avatar
jim99
jim99 is offline
Radio Removal
My dash has developed a rattle and I need to get behind the radio (1999 F150). How do I remove the radio. I see there are 4 holes located on the face cover and I assume they are the key to removal. Can anyone provide the procedure?
Thanks, JIm
Old 10-07-2001, 10:09 PM
B2Guy's Avatar
B2Guy
B2Guy is offline
Radio Removal
you are subpost to get the little tool from Ford or wal-mart(a few bucks at wal-mart)and you stick it in to the holes but Ive read on here that you get the same affect by using a coat hanger you break it in to like 2 6" peices and bend into a "U" to go into the top and bottem holes push them in and with a little work you can get it out .....in a perfect world you should take the tool put them in pull them apart a little and you feel what seems to be a spring and then pull the radio out
Old 10-09-2001, 12:22 PM
rotorhead's Avatar
rotorhead
rotorhead is offline
Radio Removal
I can vouch for the coat hanger trick. I THINK I remember that a little downward pressure was required to unlatch the radio. All I know is that I had to play with 'em for a few minutes, then all of a sudden, "CLICK" and out it came.
Old 10-17-2001, 02:26 PM
Jenks's Avatar
Jenks
Jenks is offline
Radio Removal
Mookie's 85
08-08-2016 02:34 PM
guessrow
2004 - 2008 F150
12-22-2015 03:59 PM
jim collins
12-03-2013 08:35 PM
Boonebird
20
04-02-2008 07:08 PM
f250Bill645
03-08-2005 10:41 AM
Quick Reply: Radio Removal
