RF Filter
Old Jun 26, 2008 | 10:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I think the filter you need is a pass through 100uf capacitor.
Also it hads to be rated for more amps than your unit can draw.
Old Jun 27, 2008 | 04:56 AM
Dodge/Cummins's Avatar
Dodge/Cummins
That's exactly the kind of info I'm looking for!
Thanks Dave!
Old Jun 27, 2008 | 07:24 PM
Dave Sponaugle
Most of the ones I have used asked to be mounted close to the battery.
The capacitor housing needs a good ground.
Power from the battery to the capacitor, then from the capacitor to the stereo.
The trick is after you go through the capacitor, you don't want to run your wire parallel to other wires that are close to your wire if there is any way to avoid it.
Like don't zip tie your wire to one of the truck wire looms.
Also running a ground from the battery straight to the stereo will help eliminate noise.
Old Jun 28, 2008 | 12:16 AM
Dodge/Cummins
More good info!
429unibody
Sep 19, 2012 10:19 PM
Cooter55
41
Jun 2, 2011 05:26 AM
shephard199
1997 - 2003 F150
Mar 16, 2009 10:14 PM
drtry10
Sep 1, 2008 08:48 PM
somethingurnot
Feb 14, 2004 09:39 AM
