help
Old Jun 19, 2008 | 02:26 PM
joshwhit1984's Avatar
joshwhit1984
help
does anybody know what a overdrive spring is in 99 ranger
Old Jun 20, 2008 | 09:31 PM
pawpaw's Avatar
pawpaw
Are you asking in regard to the OD switch on the end of the gear selector, or something in the transmission, or the torque converter????
Old Jun 22, 2008 | 08:05 AM
joshwhit1984
what i keep hearing is there is a spring in the transmission and that is why it won't go in to drive with overdrive on.
Old Jun 22, 2008 | 09:38 AM
Bear River's Avatar
Bear River
Former ******
Ok, start from the beginning. What are all of your symptoms. When did this start? Did it come on gradually, or all of the sudden.
Old Jun 23, 2008 | 09:06 AM
joshwhit1984
I was going toa friends house it drove fine,but when i went to go up his driveway it would not make it.I cut overdrive off and it drove up it just fine,but with overdrive on it won't do anything in drive or reverse.A few people told me it was the overdrive spring in the transmission.What do you think it is
Old Jun 23, 2008 | 09:28 AM
Bear River's Avatar
Bear River
Former ******
Sounds to me like you probably need a rebuild, at least a valve body rebuild. I do know know of this spring, I don't work on transmissions myself. But I do know that whether this spring is shot or not, you probably have a few other developing problems. Issues like yours are invariably causes by either valve body issues, or excessive wear to the bands and clutches. For now, until you can get it properly fixed, do not use OD.
