here we go....
Old Jun 19, 2008 | 09:36 AM
o4f350joe's Avatar
o4f350joe
here we go....
ok i have the 04 6.0 with edge program noticed coolant spots around the overflow tank recently then a couple days go by and im feeling a lack of power (not all the time just here and there) also just yesterday the idle jumped for a sec. two different times after starting the truck. then last night quick ride around the corner pull back in the drive way idle for a couple mins and the temp goes way up...... i fear this is def. headgaskets..... does ANYONE know of a dealer in Jacksonville FL. that might work with me on this fairly
Old Jun 19, 2008 | 12:45 PM
o4f350joe's Avatar
o4f350joe
Wtf
this can't be good... now im getting codes....
po603 internal ctrl mod kam error
p2285 injector ctrl pressure sens circ low
can anyone give me some input?????
Old Jun 19, 2008 | 01:23 PM
cartmanea's Avatar
cartmanea
The second one is an ICP sensor error, thats a fairly common problem from what I've read. Are you under the 100k engine warranty still?
Old Jun 19, 2008 | 02:22 PM
o4f350joe's Avatar
o4f350joe
i hope so trucks getting hot losing coolant ect ect... not good
Old Jun 19, 2008 | 03:05 PM
cartmanea's Avatar
cartmanea
If it has under 100k miles and a clear title it should be under warranty, call your local dealer and give them the VIN to check.
Old Jun 19, 2008 | 05:47 PM
o4f350joe's Avatar
o4f350joe
im bringing the truck to the dealer in the morning.. should i def. take the program out?
Old Jun 19, 2008 | 05:49 PM
cartmanea's Avatar
cartmanea
Yes, remove the program, then unplug both batteries and turn your headlights on. It takes 5-10 minutes to clear all memory, but you could just leave it overnight to be sure. If they find evidence of a tuner they could deny you warranty service.
Old Jun 19, 2008 | 06:05 PM
o4f350joe's Avatar
o4f350joe
Thanks for that advice man i didn't know about doing that battery thing.. you guys on this site rock
Old Jun 20, 2008 | 05:06 PM
randomhero1172's Avatar
randomhero1172
Wow great call on the battery, I assume that works with all makes/models?
Old Jun 20, 2008 | 06:39 PM
doubledee715's Avatar
doubledee715
ICP sensor issue, normal. Coolant puking with edge programmer, normal. Gauge reading "hot", possibly a faulty sensor. No need to be worried. I would be more worried about making sure you find a good tech to actually fix your truck.
superduty2001
Feb 8, 2017 12:10 PM
andrewscofield
Apr 18, 2016 11:43 AM
jed1894
Nov 25, 2015 10:18 AM
DieselHardware
Escape & Escape Hybrid
Feb 6, 2013 06:49 PM
jbwolfe
13
Dec 1, 2012 10:57 PM
