pull tranny with engine or by itself?
Old Jun 19, 2008 | 12:53 AM
muscletruck7379's Avatar
muscletruck7379
in the early 70's could the tranny be pulled with the engine (360 &np435) or does it have to be done seperatly?
Old Jun 19, 2008 | 03:11 AM
Dirt racer's Avatar
Dirt racer
I think it just depends on the front end clearance. I just pulled, painted and reinstalled my 73 thunderbird 460 with a C6 trans together, but I don't have the front end or radiator support installed. If I did I would do it separately. I did my 429 in my 75 f100 4X4 about 4 years ago and did it separately.
Old Jun 19, 2008 | 05:30 AM
swcash's Avatar
swcash
You can save a lot of work by pulling them together. Make sure you use an equalizer so that you can tilt the assembly as necessary to fit through the engine compartment.
It's a good idea to get yourself a transmission yoke to seal off the rear of the transmission while pulling it out.
Squido
Old Jun 19, 2008 | 07:34 AM
BobbyFord's Avatar
BobbyFord
I don't know why anyone would ever pull the two while still together. WAY more work.
Old Jun 19, 2008 | 11:09 AM
wizzard351's Avatar
wizzard351
ive done it both ways depending if i was going to swap from one engine family to another like if i was taking out a 302 and 3sp or auto and putin in a 429-c6 id takem both at the same time and drop in the new engine trans as a unit. but if i stay with the same style engine then just leave the trans in there
Old Jun 19, 2008 | 02:33 PM
muscletruck7379
actually taking engine and tranny out of one and putting them into a better bodied (and titled) truck
Old Jun 19, 2008 | 03:59 PM
wizzard351's Avatar
wizzard351
if this is the case id pull as a unit. this way ya dont have to fool around with torque converter nuts or clutch alinment bs,you can even leave the starter on just pull the wire off the soliniod
Old Jun 19, 2008 | 10:06 PM
Ford_Six's Avatar
Ford_Six
I pulled the engine and tranny out together on my 69, but I cheated- I pulled the front clip first.
Old Jun 19, 2008 | 10:09 PM
bigblockford_390's Avatar
bigblockford_390
I have always pulled the engine and tranny together when I make swaps. It is a tight fit getting them out with the core support still in place but it can be done.
Jeff
Old Jun 19, 2008 | 11:03 PM
BobbyFord's Avatar
BobbyFord
I have pulled at least 100 engines and have only pulled a couple still hooked to the trans. There are a lot of opinions here, so I guess it's "whatever works for you."
Old Jun 20, 2008 | 09:32 AM
wizzard351's Avatar
wizzard351
one tip tho before ya do this!!! find/make a plug(old yolk works good) for the trans tailshaft if ya dont there will be trans fluid every where when ya pullem together
Old Jun 20, 2008 | 05:58 PM
muscletruck7379
well the problem we ran into with the last one (although it had the t18 rather than the 435) was that the tranny wouldn't fit between the floorpan and the crossmember that the radius arms are bolted to. i ended up rolling the engine onto its side so the shift tower would clear.
Old Jun 21, 2008 | 12:30 PM
Ford_Ziller's Avatar
Ford_Ziller
Just pulled and reinstalled a 460 and C6 together in my 76 F100. Its a tight fit but with the radiator removed it went well. I think its quicker and easier that way. Do remember to seal the back of the tranny up with something to avoid a big mess. I forgot, won't do that again.
Old Jun 21, 2008 | 12:38 PM
19704X4F250's Avatar
19704X4F250
When you pull them together .... I found that a rattle can lid duct taped to the back of the tail shaft keeps the tranny fluid in. Don't go easy on the duct tape! That is if you don't have a spare yoke.
Old Jun 21, 2008 | 01:39 PM
BobbyFord's Avatar
BobbyFord
Or...
Powerhouse: Universal Transmission Tailshaft Plug
