Sponsored by: Auxito
Unusual Idle problem
Old Mar 8, 2004 | 07:20 AM
bjboyle's Avatar
bjboyle
I have a 1998 F-150 with a 4.6 L. As I come to a stop, the engine RPM continues dropping beyond the normal idle to around 200 RPM and occasionally the engine will stall. Hard braking seems to aggravate the problem. I've had this truck into the Ford dealer several times. Replace Idle air control valve, etc. Full emissions service and vacuum leak check. Any thoughts.
Thanks,
BJ
Old Mar 8, 2004 | 12:07 PM
BlueOvalFitter's Avatar
BlueOvalFitter
I had a 93 F150,302, that did the same thing you described.After throwing all kinds of parts at it, I finally took it to Ford.They replaced the fuel pressure regulator and fixed the problem!
Old Mar 8, 2004 | 11:27 PM
Racerguy's Avatar
Racerguy
Hi BJ and welcome to FTE
If you take it in to get the fuel pressure tested you might also get them to check and see if there are any updates for the PCM programming. I think there might be something in the calibration to fix this.
Old Mar 9, 2004 | 06:40 AM
bjboyle's Avatar
bjboyle
Thanks for the responses, the fuel pressure regulator is a new one to me, but it makes sense.
Old Mar 9, 2004 | 11:49 PM
Racerguy's Avatar
Racerguy
Please let us know what you find
Old Mar 11, 2004 | 06:55 AM
bjboyle's Avatar
bjboyle
Well, back to the drawing board, checked my records and the fule pressure regulator has been replaced. Would a pinhole in the diaphram on the brake vacuum assist cause the problem?
Old Mar 11, 2004 | 10:43 PM
Racerguy's Avatar
Racerguy
Yes but it might also cause a hard brake pedal. With the engine off let the truck sit a few minutes and then try the brakes. If it feels like there is still power brakes then you probably dont have a leaking diaphragm.
doormansamaniego
Dec 12, 2011 02:06 AM
LARIAT 85
Nov 3, 2011 05:32 PM
nosebreaker
Mar 29, 2011 08:09 PM
petie
1983 - 2012 Ranger & B-Series
Feb 3, 2005 12:16 AM
h10doc
Jan 1, 2004 08:14 PM
