Truck problems
Old Jun 18, 2008 | 09:17 PM
Chance_Thomas's Avatar
Chance_Thomas
Truck problems
Had a little trouble last week pulling my camper. Got two coded 1247 turbo boost pressure low and 1248 turbo boost pres not detected. I replaced the Ic boots and map sensor. I think maybe my turbo probably just went south.EGT's climb very very fast with the truck and no camper. Any thoughts? BTW boost gauge doesnt show anything.
Old Jun 18, 2008 | 09:19 PM
Pocket's Avatar
Pocket
You can remove the intake tube, grab the compressor shaft on the turbo, and give it a wiggle. If there's excessive play, then the turbo is gone. If it's tight and spins easily, then you just have a really big boost or exhaust leak to track down.
jhand124's Avatar
jhand124
Doesn't sound good have you taken off the intake and checked the turbo out?
Old Jun 18, 2008 | 09:21 PM
jhand124's Avatar
jhand124
Pocket you beat me to it, make sure the truck has cooled down before you grab the compressor shaft.
Old Jun 18, 2008 | 10:56 PM
Chance_Thomas
My dumb *** didn't check the IC boots after the first run. The right boot wasn't tight enough and pop off. I tightened it back down and it appeares everything is back to normal. No codes detected as well. Truck seems a little more firmer maybe I had a leak and didn't know it.
Old Jun 19, 2008 | 05:31 PM
jhand124's Avatar
jhand124
Whew glad it was easy
