Sponsored by: Innova
speaker insulation
Old Jan 4, 2002 | 10:18 PM
TCTOOL's Avatar
TCTOOL
speaker insulation
I'm puting 6 1/2's in the door of my '76. Do I need some sort of backing or insulation behind the speaker. There's nothing between the mounting hole and the door skin. What about the adhisive mats sold at Best and Circuit? Can I just set the speaker into the mat? Can the mat contact the rear magnet of the speaker?
Thanks in advance
TCTOOL
Old Jan 5, 2002 | 12:12 AM
sloth71's Avatar
sloth71
speaker insulation
you may want some sort of enclosure. They also sell foam baffles that work for weather protection. They are realatively inexspensive as well. If you want to get wild with it you could make yourself some fiberglass enclosures. but DO NOT cover up the back of the speaker as that is the way it cools itself. Hope this helps
Old Jan 6, 2002 | 06:56 PM
76RangerXLT's Avatar
76RangerXLT
speaker insulation
i put speakers in the door of my 76 and the door handles buzz, I need to do something about that.. I think I put something like 5" or 5 1/2" though, they fit perfectly... you might want to check the size on that, maybe I had 6 1/2 also but I think I remember it was in the 5's
Old Jan 16, 2002 | 09:56 PM
sloth71's Avatar
sloth71
speaker insulation
you can buy dynamat door kits, but they are waaay too expensive. There is a cheap alternative that you can find @ a hardware store like lowes or home depot. it is called peel and seal. it is around 15 - 20 bux for a 50' roll of it. it has an aluminum backing on it. Iwould reccomend a rol of that and covering the door with it. it will reduce rattles and give a better sound.
Old Jan 17, 2002 | 10:50 PM
Ryan50hrl's Avatar
Ryan50hrl
speaker insulation
e23barton
Jan 28, 2017 01:11 PM
rchouser
Aerostar
Feb 3, 2006 08:38 AM
Cruiseomatic
Dec 1, 2005 08:04 PM
jimshipp
2004 - 2008 F150
25
Jan 14, 2005 10:33 AM
