Vibration Issue
Old Jun 16, 2008 | 10:18 PM
justinglow's Avatar
justinglow
Vibration Issue
I have an 07 F-150 Super Crew 2wd Lariat. it came with factory 18's and it rode like a dream. I changed them out with factory 20's and bought a brand new set of Perelli Scorpion ATR's. The truck now has a very bad vibration in the steering wheel when you get over 60mph. The wheels have been balanced twice and they are perfect. Is that just how it rides with 20's or is it something to do with the Perillis'?
Old Jun 17, 2008 | 05:40 PM
Twinsdad98's Avatar
Twinsdad98
It's probably a little of both. 20s will make the truck ride harsher. How did they balance your wheels? Not sure who did it, but if it was done at a dealership they should force balance them for R1H. With the larger tires, the radial harmonic imbalance of the tires is worse and the correct way is to force balance the set. I'm guessing whoever mounted the tires and wheels may not have matched mounted them, but force balancing will take care if that.
Old Jun 17, 2008 | 05:50 PM
justinglow's Avatar
justinglow
Discount tire did it. I am going to bring it to the dealership and ask them to force balance it and see what happens.
Old Jun 17, 2008 | 05:54 PM
1saxman's Avatar
1saxman
'it came with factory 18's and it rode like a dream.'
Put them back on.
Old Jun 17, 2008 | 07:55 PM
FatalErrorz's Avatar
FatalErrorz
Are you 20's lug-centric or hub-centric? (One of the other mods deserves the credit for that question) If they are lug-centric, then they may not have had your rotors set right, even though the calipers were never removed, and torgued them using an impact, in a circle, instead of torquing them in the prescribed pattern found in your owners manual.
lebanontn
Aug 17, 2013 12:53 PM
Homemade
2009 - 2014 F150
Sep 27, 2012 08:33 PM
chizzy matt
Aug 1, 2011 05:58 PM
justinglow
2004 - 2008 F150
Jun 17, 2008 12:14 PM
dirtriderdan
Jun 22, 2003 01:31 PM
