FIXED my POOR A/C Performance...
Old Jun 17, 2008 | 10:17 PM
pfogle's Avatar
pfogle
The heater system is almost a separate system from the main cooling system. The heater lines are from the water pump back to the intake before the t-stat. It pumps the hot water from the bottom radiator hose, so no it won't hurt anything to put in a shutoff valve.
Old Jun 17, 2008 | 10:23 PM
bridge's Avatar
bridge
Sick 'n Tired
Thanks! It looks like I'll be stopping by home depot tomorrow.
Old Jun 18, 2008 | 12:22 AM
Spoongooner's Avatar
Spoongooner
Ran truck all day today.... it runs consistantly 10 degrees cooler with shutoff installed...
I am almost always at 40 degrees at all my vents now.. .. instead of 50-60 before valve..... it was about 111 today in Phoenix btw
Old Jun 18, 2008 | 03:59 AM
barecove's Avatar
barecove
need to keep an eye on this for a bit....just had my system recharged because of poor cooling ability... and with it being black....
Old Jun 18, 2008 | 04:46 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
for those concerned about this hurting your truck
short term:
no, unless your hoses are brittle, this mod will have no affect on your truck. you should see a little improvement in cooling ability
long term:
1. cutting flow to the heater core will cause rusting and other corrosion inside the heater core since the water will be stagnant.
2. you will be subjecting that short length of hose to higher pressure than expected. the hoses are designed for free flow, not blocked flow. shouldn't be a problem, but I would expect hose failures if the hoses are brittle
otherwise, good job and nice mod. I prefer the auto valve myself, but the manual valve is extremely easy.
Old Jun 18, 2008 | 07:47 PM
efx4's Avatar
efx4
I think I will give this some more thought, and if I decide to perform this task, it may be a good idea to go w/ a vac-actuated set up. This way there will be minimal potential ill effects on the heater core and hoses.
Old Jun 18, 2008 | 08:10 PM
1saxman's Avatar
1saxman
Hey spoongooner; nice dam fix, buddy! The heater core doesn't have a valve from the factory because of the design of the HVAC system. However, you have demonstrated the shortcomings of this simpler and more reliable system. KUDOS! The difference in the cold air temperature is dramatic and will make all the difference on a hot day. For anyone concerned with corrosion in the heater core, use the Royal Purple coolant additive and give it plenty of time to circulate through the core before turning it off. I believe this additive is safe for all coolants including Dex Cool. If I did it, I might be tempted to put in a second valve and make a bypass line which would negate any pressure concerns. The plumbing now gets a little involved, but that doesn't stop a tinkerer! So, for cooling, bypass valve open and core valve closed. For heating, bypass valve closed and core valve open.
ExBeast
Jul 13, 2016 04:24 PM
Rusty_S
28
Nov 29, 2015 07:28 PM
LARIAT 85
Jul 16, 2013 11:44 AM
rrumba
28
Jan 27, 2009 08:28 PM
trailor
1997 - 2003 F150
Feb 23, 2007 02:49 AM
