engine part question
Old Jun 16, 2008 | 03:46 PM
cps's Avatar
cps
What is that long tube that comes off the engine block just behind water pump and runs along the engine block on the drivers side? Hope this is not a dumb question.Roy
Old Jun 16, 2008 | 03:49 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Are you talking about the oil cooler? It ends at the oil filter?
Old Jun 16, 2008 | 04:12 PM
mueckster's Avatar
mueckster
There are no dumb questions. This is how we learn.
Old Jun 16, 2008 | 04:19 PM
miller_feed
Roland is right, No dumb questions here, well maybe some are.
But not questions like you asked.
Old Jun 16, 2008 | 04:39 PM
ron's power stroke's Avatar
ron's power stroke
find any part on the motor in this link..click on the pic
Old Jun 16, 2008 | 04:48 PM
cps's Avatar
cps
Smile
Thank you very much! Roy
Old Jun 16, 2008 | 04:50 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yes, that is the oil cooler. For those who don't know, there are tubes that the coolant passes through, and oil surrounds the fin-wrapped tubes. Im sure the oil gets up to around 350-400* under a heavy load, with the extreme pressure it's put on, plus the piston cooling jets have to really transmit some heat into that oil. Here are some pictures of one i repaired...
