Quick question about my gears...
Old Jun 15, 2008 | 09:03 PM
JoSHN's Avatar
JoSHN
Mainly, what gearing do I have?
I have tried using the calculator on the site and I don't think I am getting the right answer.
Basics....e4od, 4x4, 235/85R16 (31's).
1500rpm @ 50mph or 1800rpm @100kph
I had calculated it to be 2.97 or something like that.
My math is obviously wrong.
Old Jun 15, 2008 | 09:29 PM
stevilknevil's Avatar
stevilknevil
my uneducated guess would be you have 3:55's
Old Jun 15, 2008 | 09:32 PM
JoSHN's Avatar
JoSHN
Well then...sweet.
That makes me a little happier.
Old Jun 15, 2008 | 09:44 PM
stevilknevil
the only reason i think they are 3:55's is my old '87 had close to the same speed/rpm combo and it had 3:55's.
Old Jun 15, 2008 | 11:09 PM
Dave Sponaugle's Avatar
Dave Sponaugle
1500 RPM E4OD 3.55 gears on 235/85-16 tires should be doing 54.88 MPH
1800 RPM should be 107.79 KPH.
Probably a slight speedo error.
Old Jun 15, 2008 | 11:40 PM
JoSHN's Avatar
JoSHN
I'll look into the speedo issue.
I knew my math was way off though!
Old Jun 16, 2008 | 04:49 PM
stevilknevil
me and math have an arangment,i dont like it, it dont like me.
Old Jun 16, 2008 | 04:58 PM
LilDuke's Avatar
LilDuke
.71 OD on E4OD too
Old Jun 16, 2008 | 11:26 PM
Dave Sponaugle
I do to much lay out work.
Basically surveying the old school way.
I am a bit more modern though, I use spreadsheets on a computer instead of a calculator and paper.
Lots of geometry, area, and cubic volumes for cut and fill operations.
Stone backfill calculations for buildings, pads, pipes and roads.
Old Jun 17, 2008 | 02:54 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I have a fool proof system for calculating how much gravel or bags of concrete I need.
I look at it, guess how much it's gonna take and get THREE TIMES as much. It's almost perfect every time.
Old Jun 17, 2008 | 07:47 PM
1994diesel's Avatar
1994diesel
huh. i went out and looked at my truck just now and it said i have C5 gears. what is that???
Old Jun 17, 2008 | 10:29 PM
Dave Sponaugle
C5 left the factory with a 4.10 limited slip axle.
Old Jun 18, 2008 | 07:33 PM
1994diesel's Avatar
1994diesel
ok. hmm. so is this good for towing. but bad for mpgs? for better mpgs i would need 3.55?
Old Jun 18, 2008 | 10:39 PM
stevilknevil
3:55's are a good compromise.
Old Jun 18, 2008 | 11:09 PM
Dave Sponaugle
With the E4OD and 4.10 gears, you are still geared higher than I am with 3.55's and a 4 speed.
Right now you should top out at 104 MPH at 3300 RPM.
With 3.55's that would increase to 121 MPH at 3300 RPM.
1800 RPM should be about 66 MPH with 3.55's.
2080 RPM should be 66 MPH with 4.10 gears.
Where you may run into an issue with 3.55 gears is if you have to drive 55 MPH.
1500 RPM at 55 may mean running with overdrive locked out.
That could possibly cost you MPG instead of increasing it.
