Canada Trip Part 1, Remove DP-Tuner to start truck.
Folks,
This is part one of my problems while fishing in canada.
Still need to get with Jody, but wanted folks to know what I went through.
Went fishing all day monday, came off lake to load up to head back to the cabin and truck would not start. Symptom was, ABS and Check Engine light came on, ABS light would go out but SRS just stayed on. No glow light either. No white smoke, nothing. just crank and crank. Screwed around for about 1/2 hour and all of a sudden the glow light lit up and she started. WHEW!!!
Went back to cabin, got unloaded and decided to go for some supplies. Started truck left idle to grab something from the cabin. While away the truck killed and would not start again. GLAD it happened at the Cabin. :-)
Spent 30 min on phone with Ford dealer we stepped through everything he had in his schematic. Nothing helped. He asked if I had a chip installed and told him I had a DP-Tuner. He said he had seen this behavior before with chips. So, I spent another hour removing my DP-Tuner :-(. Truck fired right up. DP-Tuner is now wrapped a static bag sitting under dash. Before I reconnect I will talking to Jody at DP-Tuner.
Stay tuned for part 2 of my canada trip, it actually get worse. :-)
Ray
Ray
Ditto...so how was the fishing in canada, I used to go to the Lake of the Woods every year at this time, in fact the people I go with are there right now.
Ray,
I am checking on the chip shipment status. You last spoke to Jody on the 13th about sending it back and we have not received it yet. He is curious about why this happend after having had the chip for a couple of months. Electronics do go out, but this is strange has to how it went out.
Thanks,
Diane
Thanks,
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Chip was sent to Jody. He tested the chip and the chip is fine. When the chip first started causing problems it was set to position 2 (80 econ). Then I set it to position 0 (stock). Well, turns out I am having some sort of problem reading the documentation and set the chip to position 0 (no-start). So, when I get the chip back I will try position 2 (80 econ) and see what happens. If this does not work, I will assume I f'd up the connection on the PCM and pass on the chip all together. :-(
From the sales reciept:
0-Stock
1-60 Tow
2-80 Econ
3-120 Race
I read about "no-start" on Jody's website. I still don't understand my switch cheat sheet. Even though this appears to be a stupid user error, Jody has been very helpful and patient. Thanks Jody!
Regards
Ray
0-Stock
1-60 Tow
2-80 Econ
3-120 Race
Regards
Ray
Got chip back from Jody. His tests showed the chip is good. Reinstalled today (Sunday 9/13). And the truck started first time. I drove it around and now it seems to start intermittantly. I have another message into Jody. The good news is I have gotten really good and removing and reinstalling the chip. I will be carrying the necessary tools with me, just in case I have to remove the chip on the highway.
Regards
Ray
Regards
Ray
