I bought a fuel filter set from auto zone. It was an off brand filter set. One went on the frame and one under the hood ( the smaller one). The one on the frame looked a little different but fit just fine. It was a paper one and didn't have the screen all the way around it like the one I pulled out. Would this make the problems I had listed in the post just below under HELP MY TRUCK IS DOWN????? Thanks for all your help.
if you check out the post that bismic put up at the end of your last thread he says that non OEM filters may cause restriction which may be the cause of your truck not running right.
also after you changed the filters did you cycle the ignition on and off enough times to clear out the air from your fuel lines. if air gets pushed through one of your injectors it can cause them to fail due to their sensitive nature!
I did cycle the switch about 4 times but about 10-15 seconds a time. I will see if autozone takes back filters, who knows haha. They are full of fuel. I'll check it out tomorrow. If I do have air in the line, now what? Thanks again for all your guys' help.
