Offroad & 4x4
Front tow point??
Old Jun 14, 2008 | 11:28 PM
straightsix4x4's Avatar
straightsix4x4
Front tow point??
What are you guys using? I need to get a good sturdy one asap and those ten dollar chrome hooks that bolt on with two grade five bolts don't look all that appealing to me.
Old Jun 14, 2008 | 11:48 PM
teds74ford's Avatar
teds74ford
Front hitch here.
Old Jun 14, 2008 | 11:52 PM
rebocardo's Avatar
rebocardo
I usually use a pintle hook on a good bumper, but, here is another method.
Get 1/4" channel 4-8 inches wide, cut the length to fit inside the frame, flange to flange. Then slide it inside the frame rail, some times this requires removing the front bumper, cut a flap, sliding the metal cross member in, rewelding the frame horn.
You can use 1/2" bolts (1 each side on the 4") to hold it in place along with the two tow hook bolts.
Old Jun 15, 2008 | 12:05 AM
straightsix4x4
hmm, I think I gotcha, pics would help. I assume your using some other kind of tow hook then those ten dollar ones?
Old Jun 15, 2008 | 01:41 AM
75F350's Avatar
75F350
Front reciever here too.
I got a little creative and used a late 90's F150 rear reciever that I cut down to fit between the frame horns. Once I turned the reciever upside down, it fit perfectly behind the front license plate. I made a license plate mount that plugs into the reciever (that keeps the cops happy), and when I head off-road, I install d-ring shackle.
Works for winch mounts etc...
Image of front reciever - Photobucket - Video and Image Hosting
Old Jun 15, 2008 | 07:11 AM
STGFordCrazy04's Avatar
STGFordCrazy04
Keep the ideas coming. Im looking for something as well.
Old Jun 15, 2008 | 01:35 PM
Packrat Super duty's Avatar
Packrat Super duty
Did you weld it to the Frame, or Bolt it?
I'm working on building a new bumper with the receiver bult into the center and recessed back between the frame. That way when I install the winch (with receiver pipe and frame already built) the front plate for the winch mount will sit flush with the front of the bumper. When the winch is removed (so it could be installed on the back, to pull you back out of an ugly situation) I will have a plate that drops into the receiver on the front, to fill the gap. (This also reduces the weight of the winch on the front of the truck, when not out puddle jumping)
Old Jun 15, 2008 | 01:53 PM
master_mechanic's Avatar
master_mechanic
I use two tow hooks off the 88-98 chev (yeah i know its a chev part on a ford but ford never made tow hooks in those days) there bolted with two grade 8 half inch bolts in hole i drilled in the frame, I hade to notch out my bumper so the hooks would clear but i think it look mean.
Old Jun 15, 2008 | 03:37 PM
75F350's Avatar
75F350
I welded mine. I did not have enough room for fasteners. The steering box is on the way, and the heads for the bolts would have required more fabrication than I was willing to perform.
With a 78/9 steering box, this hitch could easilly be bolted in, but I used a saginaw, that sits outside of the frame rail, and it is tight where it is mounted, and 4 bolt heads behind the box would have made this combo a nightmare.
Old Jun 15, 2008 | 03:58 PM
Packrat Super duty
OK, that's good to know. I haven't removed the front factory bumper yet on the 91, to see what all is going to be involved. I just know somethings gotta happen to the front end...... With the lift kit I can barely reach the dip stick to check oil, a bumper out front that you can stand on. can be very usefull, in a tall truck.
I will probably do the same and weld the receiver in place. Then bolt the tube bumper on.
Old Jun 15, 2008 | 06:25 PM
straightsix4x4
I've seen enough of those on stock trucks bent straight or broke clean off that I want nothing to do with them. I'm way to hard on things
Old Jun 15, 2008 | 06:29 PM
straightsix4x4
I really like this, tough, out of the way, I will be keeping my eye out in the jy for reciever hitches... we'll see what else is working to
STGFordCrazy04
yup. I DO NOT hook my truck to them. Real POS's.
So far the best factory tow hooks Ive seen are on the SDs and the dodge 2500s. Both are closed loop designs.
Old Jun 15, 2008 | 06:33 PM
straightsix4x4
agreed, I don't remember what I saw it on but it was closed with a big thing sticking out in the middle for easy tow strap hook up, looked to me like that tang could break off and become a bullet, just a thought, never seen it. I think this was on a 2500 ram.
Old Jun 15, 2008 | 06:35 PM
STGFordCrazy04
yup thats the one.
I wouldnt loop the strap around like it was intended. Id put a shackle through it and connect it to a strap.
