rear leaf spring broken pin???
Old Jun 14, 2008 | 08:32 PM
pipman76's Avatar
pipman76
my truck has something wrong but not for sure what it is ,i think its a broken pin in the leaf sring on the driver side but not sure,it doesnt drive bad but if u stand from behind the truck and look down boths sides of the truck u see the drivers rear tire and wheel look s warped or **** sided,ive even did a tire rotation from the front and still looks the same ,so its not a warped rim ,i even changed the axle,brakes,hub so if its not the leaf spring is there anything else to check,i have a whole parts truck so what ever i need to replace i can thanx guys for any help
Old Jun 15, 2008 | 12:33 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
get out a tape measure, and start measuring things. i dont see how the truck can have anything "warped". buy a new set of springs if it isnt level from side to side. if the leaf spring pin is snapped, youre wheelbase should be different on one side (distance from center of front tire to center of rear tire) i have never heard of this problem before. has the truck been abused? is the axle housing bent? this is almost impossible however. we need more specific info though. try comparing the truck to youre other one. good luck.
Old Jun 15, 2008 | 02:13 AM
just-n-time's Avatar
just-n-time
I have seen the truck frames bent, though it was a hard hit on a high curb that did the job, remember these are old trucks they only take so much abuse! but you can try doing a center alignment go from frame to center of tire on each side one has to be out, look at the bushings in the spring hangers, see if the spring is against the metal hanger, they should have rubber between the metal parts. If all that dose not yield another question then find a long straight edge and place it on the frame, you just never know!
Old Jun 15, 2008 | 02:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Sounds like one of the leafs in your rear springs has broken.
This causes the rear end to shift over to one side and then the vehicle "dog tracks."
Have someone follow behind you down the road...and look at the rear tires...if they can also see the front tires, one of your real leafs is broken.
The only "pin" is the eyebolt that bolts the entire spring pack together.
It goes through the center of the leaf springs (between the U clamps), and if that breaks (it rarely does)...that's EZ to spot.
NOTE: While the left (drivers side) wheel looks ****-eyed, the spring could be broken on the right side.
LaxPlaya21
Jun 28, 2014 09:46 PM
_Rick_
Aug 11, 2010 01:09 PM
wilbur996
Apr 4, 2010 10:00 AM
pipman76
18
Jul 5, 2008 06:06 PM
GammaDriver
Apr 21, 2002 02:03 PM
